Intel Pentium PRO 200 question
Reply 20 of 26, by maxtherabbit
luckybob wrote on 2022-05-23, 02:51:
Dump it.
Ounce of prevention is worth a pound of cure
Since you're here I feel I should inform you I will be documenting a PR440FX build here in the coming weeks
Reply 21 of 26, by TrashPanda
Dump it.
It does have Adaptec SCSI on board along with some Cirrus Logic GPU, wonder if they are part of the on board BIOS or are running alongside of it.
Reply 22 of 26, by luckybob
I'd wager heavily on all of those devices having their bios code mixed into one chip.
Reply 23 of 26, by TrashPanda
luckybob wrote on 2022-05-23, 05:49:
Might actually be worth dumping the Bios then, Have to strip the system shortly as it needs a good clean and I want to throw a 1mb PPro in there, still waiting on the FPM Simms to arrive so I can deck the system out, might see if I can throw a SCSI HDD in there or a SCSI CDROM, perhaps both as its using IDE right now.
Reply 24 of 26, by PC Hoarder Patrol
debs3759 wrote on 2022-05-22, 22:23:
ontrca wrote on 2022-05-22, 21:37:
Would anyone be interested in seeing a bootup screen picture?
Maybe tomorrow? 😀
Bootup screen will be appreciated for UltimateRetro website, as will a dump of the BIOS
BIOS files are still reachable on Wayback...
The attachment Soltek SL-60A_65A BIOS Files.jpg is no longer available
https://web.archive.org/web/20030329224329/ht … bios/60a-b1.bin
https://web.archive.org/web/20030329224329/ht … bios/60a-b2.bin
https://web.archive.org/web/20030329224329/ht … bios/60a-b3.bin
...along with the associated manuals
The attachment Soltek SL-60A.pdf is no longer available
The attachment Soltek SL-65A.pdf is no longer available
Reply 25 of 26, by ontrca
luckybob wrote on 2022-05-22, 22:35:
https://i.imgur.com/WzeqyzC.jpg […]
I would have been here earlier but I was watching a 100-minute expose on Babylon 5. ( https://www.youtube.com/watch?v=-FfKOubWE14 )
Welcome to the Pentium-Pro master race!
Ironically, those thermal pads often worked better than typical heat sink compound (of the time). Tolerances for heatsinks were very loose by today's standards. The pads were often better than goop until the pentium 3 /athalon era when they flipped the die to allow direct exposure.
I also want to echo @debs3759's request for a bios dump, boot images, and proper board pictures.
Reply 26 of 26, by luckybob
Excellent.
