First post, by ColdBrain
I want to create a batch menu for the GOG version of Blood, for use with D-Fend Reloaded. I'll point the batch file to either of the game executables (BLOOD.EXE and CRYPTIC.EXE). But I want to add some bells and whistles to it, like a box around the text. Is there a tutorial for it? I found one, but it requires me to have DOS files and I don't have DOS installed.
Thanks in advance.
Reply 1 of 8, by leileilol
There was a very old (1987) program that would do exactly this, to generate an ASCII box with a menu system for batch file editing afterward. Forget what it was called though, might've had a stupidly simple name like 'makemenu' or something.
FUCK "AI"
Reply 2 of 8, by zirkoni
Something like this?
@echo off
:start
cls
echo ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ»
echo º Menu º
echo ÌÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ͹
echo º 1. Blood º
echo º 2. Cryptic Passage º
echo º 3.+ MODS º
echo º 4.+ Multiplayer º
echo º 5.+ Editors º
echo º 6. Setup º
echo º 7. DOS Prompt º
echo º 8. Exit º
echo ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ
choice /c12345678 /N Your choice:
if errorlevel 8 goto exit
if errorlevel 7 goto prompt
if errorlevel 6 goto setup
if errorlevel 5 goto editors
if errorlevel 4 goto multi
if errorlevel 3 goto mods
if errorlevel 2 goto cryptic
if errorlevel 1 goto blood
:editors
cls
echo º Menu º
echo º 1. Blood º
echo º 3.+ MODS º
echo º 5.- Editors º
echo º a. Art Editor º
echo º b. Map Editor º
echo º º
echo º 6. Setup º
echo º 8. Exit º
choice /c12345ab678 /N Your choice:
if errorlevel 10 goto exit
if errorlevel 9 goto prompt
if errorlevel 8 goto setup
if errorlevel 7 goto maps
if errorlevel 6 goto art
if errorlevel 5 goto start
:multi
cls
Show last 27 lines
echo  º        Menu         º
echo º 1. Blood º
echo º 3.+ MODS º
echo º 4.- Multiplayer º
echo º a. Startserver º
echo º b. Connect º
echo º º
echo º 6. Setup º
echo º 8. Exit º
choice /c1234ab5678 /N Your choice:
if errorlevel 7 goto editors
if errorlevel 6 goto connect
if errorlevel 5 goto startserver
if errorlevel 4 goto start
etc...
This is what it looks like in DOSBox:
https://youtube.com/@zirkoni42
Reply 3 of 8, by ColdBrain
Oh well, thanks for the code! But I also wanted to learn to do them myself. Still, this will be very useful. 😀
Reply 6 of 8, by chinny22
But now you do!
Mess round with it and see how it works 😀
I do the same thing for old shareware titles like Duke Nukem, Jill of the Jungle, etc where each episode was a separate executable.
Reply 7 of 8, by Daniel3D
keropi wrote on 2016-06-20, 08:49:
http://reimagery.com/fsfd/menu.htm , check out "Medley" in "OTHER SMALL MENUS" section
The site has degenerated to the internet archive. But the zip is still available.
(although for me, the first solution worked wonderfully.) This is indeed a nice tool.
Medley is a small yet remarkably full-featured menu program. The program is only 6K and uses a modest 12K RAM when resident.
A second program is used for menu/display configuration, or you can manually create and edit menu files with a text editor.
Features:
  • Submenu capability (no more than two levels recommended)
  • Menu selection is accomplished with user-definable hotkeys- or by moving a menu bar to the desired item.
  • Option to prompt for filespecs/parameters when a menu item is selected.
  • Built-in pop up DOS command line menu option.
  • Menu title and colors are adjustable.
  • Built in screen blanker and date/time display.
Limitations:
  • Maximum of 20 menu items allowed per menu file.
  • No mouse support.
Author: Jim Knopf, aka Jim Button (1992).
1992-07-30 release.
