First post, by Presbytier
- Member
So, I am running Windows 11 and I can get Heretic II to run either using the 1.06 Enhancement Patch or the 1.07 one. Unfortunately on either one the game will crash if I try to load a save game. This was not as big of deal because it would allow you to load a level. However once I got to the second main area in the game you have to backtrack into other levels and if you do that the game crashes. I can't remember if I had a similar issue on Windows 10 because that was a long time ago now. So basically the game crashes when loading a save or backtracking into a prior area played.
"Never pay more than 20 dollars for a computer game" - Guybrush Threepwood
