First post, by BinaryDemon
Silly question, I like looking at interesting things on eBay and saw this product- Kingston KVR-GPA/4 4mb GPA for AGP video
Sorry for the crappy pic, I didnt want to link an eBay auction and this was the next best image I saw .
But I can’t find much documentation for it online. Was this for specific OEM systems or would it work with the memory for almost any integrated agp? Does it replace the memory or add to it? 4mb doesn’t seem like a lot either way.
Reply 1 of 13, by zyga64
It is designed for i815 (and maybe i810) based motherboards. I'm sure it was mentioned in the user manual for Compaq computers.
AIMM module: https://www.anandtech.com/show/569/3
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /Trio64V2DX+3dfx /ES1370
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 2 of 13, by BinaryDemon
Good info, thanks.
Reply 3 of 13, by Putas
Is it the 100 MHz version? My 133 Mhz module looks like this:
Reply 4 of 13, by swaaye
Interesting. So it's a way to add the "display cache" RAM to a 815 motherboard?
Reply 5 of 13, by kitten.may.cry
I owned one of these things, without any way of knowing what that was, as my 810 experience was quite limited, and pretty negative.
God bless 815\694X.
Reply 6 of 13, by Putas
swaaye wrote on 2022-05-30, 18:08:
Yes.
Reply 7 of 13, by Error 0x7CF
Are there any benchmarks comparing a display-cached i815 to a system-memory-only i815? I looked around and couldn't find any.
Old precedes antique.
Reply 8 of 13, by Standard Def Steve
IIRC some Compaq Deskpro EN pizza boxes had the 4MB display cache built right into the motherboard.
"A little sign-in here, a touch of WiFi there..."
Reply 9 of 13, by Putas
Error 0x7CF wrote on 2022-05-30, 21:23:
I could not finish that before vacation, but it did account for ~20 % uplift on my system with 133 MHz RAM.
Reply 10 of 13, by Error 0x7CF
Wow, 20% uplift might make the i815 graphics almost usable!
Reply 11 of 13, by PC Hoarder Patrol
Putas wrote on 2022-05-31, 04:55:
20% sounds about right for the then quoted figures, but I'd have to say that in my (short!) time using one on an Abit SA6R I never really noticed much improvement - Intel liked to quote 30% and the one I got from Crucial / Micron noted around the 25% mark. I also have an PCI-only i810E slot 1 / skt 370 combo board (Jetway J-913AF) with the 4MB display cache onboard.
For reference, here's my Crucial AIMM (166MHz with Hyundai ICs)...
The attachment CT1M32S4A6 AIMM.jpg is no longer available
https://web.archive.org/web/20010826203652/ht … dule=CT1M32S4A6
The attachment Crucial 66-pin AIMM.jpg is no longer available
Reply 12 of 13, by Jasin Natael
Standard Def Steve wrote on 2022-05-30, 23:02:
This is correct. I have one but never used the onboard graphics on that system. I should try it for giggles sometime....
Reply 13 of 13, by Babasha
iP3 1133MHz, HP VL410 mobo, 2x PC133 256MB , Win98
Quake2 - 40fps (without AIMM), 55fps (with AIMM).
Quake3 - 31fps (without AIMM), 44fps (with AIMM).
Need help? Begin with photo and model of your hardware 😉
