ATI Radeon X850XT Platinum Edition
Reply 20 of 40, by mawendir
So many great advices and thought, appreciated a lot guys! Also glad to hear that it's worth the trouble. I'll be selling my uncompatible MoBo, CPU, broken GPU and RAMs and go for new hardwares that are compatible with my X850XT PE. I find P4 CPUs easily but when it comes to W98 compatible MoBo with PCI-E x16, it gets a bit hard. To be fair, if I ever get my build working, I'll consider making it dual boot too. @bloodem, could you please share your dual boot rig so I can be enlightened more, to show me the way? Thanks in advance!
Reply 21 of 40, by bloodem
mawendir wrote on 2022-05-30, 18:17:
I have multiple dual boot rigs 😁
But I know what you mean. My current fastest Win98 + WinXP rigs are:
PC1:
MB: Gigabyte GA-EP45-UD3R
CPU: Core 2 Duo E8600, OC @ 4 GHz
RAM: 2 GB DDR2 800 (using Rudolph R. Loew's patch)
VGA: POWER COLOR ATI RADEON X850XT PCI Express (520MHz core / 1080MHz memory)
DIRECTX 8.1
120 GB Kingston SSD
SOUND: Audigy 2 ZS
PC2:
MB: ASUS P5KPL-AM SE
CPU: Core 2 Duo E8600 OC @ 4 GHz
VGA: SAPPHIRE ATI RADEON X850XT PCI Express (520MHz core / 1080MHz memory)
DIRECTX 8.1
120 GB Kingston SSD
SOUND: Audigy 2 ZS
BENCHMARK RESULTS WITH "PC2" in Win98 (although both systems perform basically the same):
3DMark99 Max: 50253 / 106479
3DMark2000: 50901 3DMarks / 1810 CPU Marks
3DMark2001: 41520 3DMarks
GLQuake 640 x 480 x 16: 1459.3 FPS
GLQuake 640 x 480 x 32: 829.1 FPS
GLQuake 1024 x 768 x 16: 504.3 FPS
GLQuake 1024 x 768 x 32: 408.0 FPS
GLQuake 1600 x 1200 x 16: 399.6 FPS
GLQuake 1600 x 1200 x 32: 381.4 FPS
Quake 2 640 x 480 x 16: 994.2 FPS
Quake 2 640 x 480 x 32: 994.2 FPS
Quake 2 1024 x 768 x 16: 991.4 FPS
Quake 2 1024 x 768 x 32: 971.8 FPS
Quake 2 1600 x 1200 x 16: 672.2 FPS
Quake 2 1600 x 1200 x 32: 601.2 FPS
Quake 3 640 x 480 x 16: 979.0 FPS
Quake 3 640 x 480 x 32: 976.0 FPS
Quake 3 1024 x 768 x 16: 795.5 FPS
Quake 3 1024 x 768 x 32: 675.6 FPS
Quake 3 1600 x 1200 x 16: 531.0 FPS
Quake 3 1600 x 1200 x 32: 456.5 FPS
Quake 3 1600 x 1200 x 32: 382.3 FPS (MAX TEXTURE DETAIL + TRILINEAR TEXTURE FILTER)
MDK2 640 x 480 x 16: 1091.77 FPS
MDK2 640 x 480 x 32: 1085.72 FPS
MDK2 1024 x 768 x 16: 833.13 FPS
MDK2 1024 x 768 x 32: 659.69 FPS
MDK2 1600 x 1200 x 16: 431.21 FPS
MDK2 1600 x 1200 x 32: 392.11 FPS
MDK2 1920 x 1440 x 16: 370.81 FPS
MDK2 1920 x 1440 x 32: 324.62 FPS
Unreal 640 x 480 x 16: AVG 693.48 FPS / HIGH 1318.09 FPS / LOW 340.76 FPS
Unreal 640 x 480 x 32: AVG 670.17 FPS / HIGH 1248.49 FPS / LOW 325.66 FPS
Unreal 1024 x 768 x 16: AVG 633.59 FPS / HIGH 1173.88 FPS / LOW 332.65 FPS
Unreal 1024 x 768 x 32: AVG 591.08 FPS / HIGH 1044.44 FPS / LOW 310.30 FPS
Unreal 1600 x 1200 x 16: AVG 464.26 FPS / HIGH 667.95 FPS / LOW 277.77 FPS
Unreal 1600 x 1200 x 32: AVG 377.42 FPS / HIGH 574.50 FPS / LOW 226.90 FPS
Unreal 1920 x 1440 x 16: AVG 339.86 FPS / HIGH 493.96 FPS / LOW 208.85 FPS
Unreal 1920 x 1440 x 32: AVG 283.37 FPS / HIGH 442.44 FPS / LOW 165.73 FPS
Expendable 640 x 480 x 16: AVG 756.78 FPS / HIGH 909 FPS / LOW 611 FPS
Expendable 640 x 480 x 32: AVG 755.57 FPS / HIGH 909 FPS / LOW 611 FPS
Expendable 1024 x 768 x 16: AVG 736.35 FPS / HIGH 876 FPS / LOW 617 FPS
Expendable 1024 x 768 x 32: AVG 735.71 FPS / HIGH 874 FPS / LOW 616 FPS
Expendable 1600 x 1200 x 16: AVG 544.47 FPS / HIGH 653 FPS / LOW 489 FPS
Expendable 1600 x 1200 x 32: AVG 525.28 FPS / HIGH 629 FPS / LOW 458 FPS
Expendable 1920 x 1440 x 16: AVG 424.15 FPS / HIGH 493 FPS / LOW 356 FPS
Expendable 1920 x 1440 x 32: AVG 385.51 FPS / HIGH 456 FPS / LOW 325 FPS
Some of the games that I tested in Win98 (and they all work without a hitch):
- GLQuake
- Quake 2
- Quake 3
- MDK2
- Unreal
- Unreal Tournament
- Expendable
- Need for Speed 3 Hot Pursuit
- Need for Speed High Stakes
- Need for Speed Porsche
- Need for Speed Hot Pursuit 2
- Nocturne
- GTA 3
- GTA Vice City
- Final Fantasy 7 (with 1.02 Riva 128 patch, because Radeon cards DON'T have 8-bit paletted textures support in Win98)
- Prince of Persia 3D
- Return to Castle Wolfenstein
- Re-Volt
- Tomb Raider 3
- Tomb Raider The Last Revelation
- Tomb Raide Chronicles
2 x PLCC-68 / 4 x PGA132 / 5 x Skt 3 / 1 x Skt 4 / 9 x Skt 7 / 12 x SS7 / 1 x Skt 8 / 14 x Slot 1 / 6 x Slot A
Current PC: Ryzen 7 9800X3D
Backup: Ryzen 7 5800X3D
Reply 22 of 40, by Joseph_Joestar
bloodem wrote on 2022-05-30, 19:12:
Those are some seriously awesome numbers!
Running games at 1600x1200 and having your minimums be in the 200 FPS range is nothing short of amazing. 😀
Reply 23 of 40, by Tetrium
cyclone3d wrote on 2022-05-29, 20:21:
You can go all the way up to at least the x79 chipset for 98SE. Pretty sure x99 should work as well.
As long as the motherboard supports legacy (BIOS) boot an not only UEFI boot it should work.
Wouldn't this be roughly making it at around the same vintage of hardware where WinXP stops being supported?
My retro rigs (old topic)
Report spammers here!
Reply 24 of 40, by bloodem
Joseph_Joestar wrote on 2022-05-30, 19:24:
Yeah, it’s pretty wild. I especially enjoy playing with these systems after doing extensive benchmarks on very slow hardware. I get a real kick out of the performance jump every time. 😁
Reply 25 of 40, by mawendir
Awesome rig with awesome results! I just found GIGABYTE GA-8VT880P COMBO rev 2.0. You guys think it'd be compatible with W98?
Reply 27 of 40, by fosterwj03
Windows 9x runs fine on Core 2 and Core i processors. Unfortunately, Win 9x will only use one core. On the plus side, the Core i processors will turbo on one core. My best clock speed with Win 9x to date is 3.8GHz on a Core i5-3570 stock. Core i7 K-models could go a bit faster.
I use an x800 XL with my overkill Win 98 system, and I love it. I run the resolution at 1080p, including in games (when possible).
Reply 28 of 40, by appiah4
I have an LGA775 Win98SE/AntiX dual-boot box with a C2D E4600, Radeon X800XT PE PCIe and 2GB RAM. It is blissfully fast, I love it. Do it.
For what it's worth my advice would be to go with a VIA P4M890 motherboard. That makes it really easy to set up Win98 and you can also have DOS Sound through a PCI card such as YMF7x4 (or FM801, etc.).
Reply 29 of 40, by mawendir
appiah4 wrote on 2022-05-31, 11:03:
Thank you for your precious advice. I've just found BIOSTAR P4M890-M7 SE (ver. 7.1) with VIA P4M890 / VT8237A chipset but it says that it supports Windows 2000 and XP. No mention about 98 SE. Would it be compatible with it anyway?
Edit: It turns out that MoBo doesn't support E8500 (which I'll be buying soon), so will look up for something else. What about Foxconn P4M8907MA-RS2H? I'm unable to find any useful or official information about it, yet.
Reply 30 of 40, by appiah4
mawendir wrote on 2022-05-31, 14:34:
Exact same board as the one I use. The fastest you can go is an E6600 with it, and it should be more than enough. Yes, 98SE works like a charm on it.
Reply 31 of 40, by mawendir
You think it should be enough for some of early-mid XP games, which won't be much demanding? I don't think that it'll be a problem to be honest but I'm doing this only once, I'm confused if I should try to find a W98 compatible MoBo with E8500 support? Or should I just go with E6600?
Reply 32 of 40, by appiah4
E8500 should be about 40% faster. That said I think E6600 would be enough.
Reply 33 of 40, by mawendir
What about Asus P5KPL-AM SE? I know Phil's using it in his video but haven't found anything more specific about Windows 98 with this board. Should I buy it and E8500?
Reply 34 of 40, by bloodem
mawendir wrote on 2022-06-01, 16:59:
Uhm... Are you sure you haven't found anything specific? 😀
I mean... all the Win98 benchmarks that I listed in a previous post (on this very same page) were done on the P5KPL-AM SE + E8600.
Again:
- Yes, this board, the P5KPL-AM SE (and many others like it) works fine with Win98 and you don't need to install any chipset drivers.
- Will it be an easy and straightforward process? Depending on your particular X850XT model (and your skills), it might. But there's also a possibility that further tweaking might be required (maybe even modifying & reflashing the video card's BIOS, as it was pointed out in some previous posts).
Reply 35 of 40, by mawendir
Oh, sorry, I've been googling this board for almost a day and haven't found anything and totally forgot about your post. I hope it won't be a huge pain but I believe it'll definetely worth it. Again, it's my bad and thanks a lot for all of your time and information! Helpmed me a lot.
Reply 36 of 40, by mawendir
So here is my latest build;
MoBo: Asus P5KPL-AM SE
CPU: Intel Core 2 Duo E8500
GPU: ATI RADEON X850 XT Platinum Edition
RAM: 2x 1GB 800MHz CL5 DDR2
SSD: 128 GB SATA SSD
Sound Card: Creative Sound Blaster Audigy 2 ZS
My question is, how many watts do I need for this machine, I need a PSU. Would 300W be enough?
Reply 37 of 40, by chrismeyer6
300 might be ok if not a bit tight I'd personally go with a good quality 500 watt or higher unit.
Reply 38 of 40, by bloodem
mawendir wrote on 2022-06-08, 15:31:
So here is my latest build; […]
Nice build, very similar to mine. 😀
As far as I remember, the max power consumption (as measured at the power outlet) is about 150 Watts.
So any modern PSU will do, but, as always, I recommend one of decent quality.
Reply 39 of 40, by mawendir
bloodem wrote on 2022-06-08, 16:14:
Nice build, very similar to mine. :-) As far as I remember, the max power consumption (as measured at the power outlet) is about […]
Thanks a lot, I got a 250W PSU already, gonna try it out first and see. Just two more questions. Is there a guide to install SATA SSD to W98 machine? And is it enough just put the sound card to PCI slot and will it work just fine, or do I need to plug a cable in to make the sound work?
