First post, by caltrop
- Newbie
DOSbox serial has always been an issue with all my systems
back through Mint Mate 18.1
it is erratic at best, sometimes working, most times not
I use several programs that require serial interface through DOS:
HP48 PDL & HP version of Columbia University Kermit Transfer
Windows XP requiring serial works flawlessly in the virtual machine
only DOSbox has issues
then there is the MIDI issue...
which makes old DOS worthless
I even set the irq & portserial1=directserial realport:ttyUSB0 irq:4 port:0x3f8#serial2=directserial realport:ttyUSB1 irq:3 port:0x2f8
crw-rw----+ 1 root dialout 188, 0 2022-05-11 21:18 /dev/ttyUSB0chmod to all read writecrw-rw-rw-+ 1 root dialout 188, 0 2022-05-11 21:18 /dev/ttyUSB0
serial status using various utilities:Bus 001 Device 108: ID 2478:2008 Tripp-Lite U209-000-R Serial Port/dev/ttyUSB0, UART: 16654, Port: 0x0000, IRQ: 0crw-rw-rw-+ 1 root dialout 188, 0 2022-05-11 21:18 /dev/ttyUSB0MAJOR 188MINOR 0ID_PCI_CLASS_FROM_DATABASE Serial bus controllerID_PCI_SUBCLASS_FROM_DATABASE USB controllerID_PCI_INTERFACE_FROM_DATABASE XHCIID_VENDOR_FROM_DATABASE Tripp-LiteID_MODEL_FROM_DATABASE U209-000-R Serial PortID_SERIAL 2478_2008ID_USB_DRIVER pl2303groups: caltrop adm dialout cdrom sudo dip plugdev lpadmin sambashare
dosbox log file I created
$ dosbox > dosbox.log &
================================================================================2022-05-11 20:52:58 Wed--------------------------------------------------------------------------------DOSBox version 0.74-3Copyright 2002-2019 DOSBox Team, published under GNU GPL.---CONFIG:Loading primary settings from config file /home/caltrop/.dosbox/dosbox-0.74-3.confMIXER:Got different values from SDL: freq 22050, blocksize 512ALSA:Can't subscribe to MIDI port (65:0) nor (17:0)MIDI:Opened device:noneSerial1: Opening ttyUSB0One joystick reported, initializing with 4axisUsing joystick STD AxisPad with 4 axes, 20 buttons and 1 hat(s)Serial1: Errors: Framing 0, Parity 0, Overrun RX:13 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:21 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:13 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:21 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:13 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:21 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:13 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:21 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:13 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:21 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:13 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:14 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:13 (IF0:0), TX:0, Break 0Serial1: Errors: Framing 0, Parity 0, Overrun RX:21 (IF0:0), TX:0, Break 0
