Weird OMTi 486 mb
Reply 20 of 30, by Tiido
206 parts are mostly fully compatible "integrated perhipherals controllers", clones of Chips 82C206. Many manufacturers made them and they're often paired with many chipsets.
Reply 22 of 30, by Al Kossow
well, I was updating the VIA datasheets section on bitsavers this morning, and discovered that the 100 pin part seems to match the pinout of their 82C416. The description seems to match the functionality as well.
so BOTH boards have the wrong parts ???
wish I could find info on the 406
Reply 23 of 30, by Al Kossow
In the process of doing a chip swap, this is what was found under the parts.
so as I suspected BOTH boards have the wrong parts
Reply 25 of 30, by Al Kossow
No, positively absolutely BOTH boards were stuffed with the WRONG chipset
No other part from other vendors functions the same as the 82C406.
The parts put down on the boards were WRONG
Now, I have to figure out all of the missing jumpers and try a BIOS for the correct
chipset. I have one from a single board industrial computer that may work to the
point where POST codes come out.
Reply 26 of 30, by Al Kossow
did someone on the list buy this ratty mb https://www.ebay.com/itm/198029689977 (hopefully they got it cheap)
I'm interested in a dump of the bios
Reply 27 of 30, by weedeewee
Al Kossow wrote on 2026-01-21, 16:23:
FYI, seems to be another version of this https://theretroweb.com/motherboards/s/fic-486-pvt-rev.-b2 or b1
Do not ask Why !
Reply 28 of 30, by Al Kossow
cool. and that has a 5.12 bios
Reply 29 of 30, by Al Kossow
I still haven't given up on trying to bring that weird via chipset board with no keyboard controller or separate clock generator back to life
I didn't see any 5.xx award bios listed in the retro web award bios table
Reply 30 of 30, by Al Kossow
I also notice the chips list incorrectly lists the 82c416 instead of a 82c406
