Reply 60 of 113, by Stryker1996
Joseph_Joestar wrote on 2022-06-14, 16:06:
It depends on how you want to play Win9x era games and how you define that period. Personally, I consider Windows games released […]
Stryker1996 wrote on 2022-06-14, 15:08:
Well to me I think that going above any 3dfx card would be overkill, it's like with processors, you would rather use a pentium 3 than a core 2 duo.
It depends on how you want to play Win9x era games and how you define that period. Personally, I consider Windows games released from 1996 up to (and including) 2001 as the Win9x era. Other people might have different views.
As to how you want to play these games, some folks like to use a CRT monitor and play at the period correct resolutions e.g. 1024x768 and below. Others prefer to run Win9x games at 1600x1200 with AA and AF fully maxed out at 60+ FPS. In the latter case, you need something like a Radeon X850 to play some of the more demanding 2001 games like Max Payne at those settings. But if you stick to period correct resolutions, and don't mind if a few of the later games drop below 60 FPS, even a Voodoo3 will be enough.
It's similar with the CPU choice. A Pentium 3 Coppermine at 1 GHz will run most Win9x era games very smoothly. But there are a few genuinely CPU demanding titles out there (such as the original Deus Ex) which may struggle to reach 60 FPS on that setup. This is why some people go with a high-end Pentium 4 or Athlon 64 system.
Well I would aim for above 30 fps, I watched an lgr video on the diamond s3 savage 4 pro+ and it has better FPS and the graphics are better, but it runs Max Payne badly
Reply 61 of 113, by leileilol
Remedy's MAX-FX engine never got along with any S3 Savage products including the following Savage2000 series.
Reply 62 of 113, by swaaye
Savage cards are solid for most games on Quake(s)/Unreal 1 engines but outside of those don't get your hopes up.
I think the most interesting thing to do with them is play with S3TC tech demos and UT with S3TC.
Reply 63 of 113, by Stryker1996
But it's worth it for the texture compression
Reply 64 of 113, by Joseph_Joestar
Stryker1996 wrote on 2022-06-15, 07:36:
Note that only a couple of textures on each Unreal Tournament map use S3TC, usually some floors, certain walls and a few crates. The majority of the textures still look normal on an S3 Savage card.
Additionally, I think you lose Detailed Textures (different thing from compressed textures) when the S3 Metal renderer is used, so it's a trade off. You can read more about that in this thread: S3 Savage MeTal API 3D Accelerated Games List
Reply 65 of 113, by appiah4
Joseph_Joestar wrote on 2022-06-15, 07:54:
To be fair ground textures make up for about 50% of the FOV so any improvements on those textures and their filtering has more impact on IQ than other things like objects etc.
Reply 66 of 113, by leileilol
IQ is very subjective here when a lot of those special S3 textures are obvious photoshop filter jobs. Plus, S3's novelty was only exclusive for like a year anyway when S3TC started appearing on other cards soon after and cwdonhal's UT GL renderer would come to support them.
Reply 67 of 113, by Joseph_Joestar
appiah4 wrote on 2022-06-15, 08:36:
I would agree if all ground textures on all maps were compressed. But they aren't.
Heck, on certain maps, one room uses compressed textures on the floor while another one right next to it doesn't. It's really weird.
Reply 68 of 113, by Stryker1996
leileilol wrote on 2022-06-15, 08:54:
I got it from lgr and I don't think he would photoshop
Reply 69 of 113, by Stryker1996
What if I use a dual socket tualatin board with 2 1.4 ghz pentium 3's
Reply 70 of 113, by Joseph_Joestar
Stryker1996 wrote on 2022-06-15, 12:41:
Windows 98 only recognizes one CPU, so having a dual socket configuration would not get you any extra performance. You would need Windows NT, 2000 or XP to benefit from such a setup.
That said, a 1.4 GHz Tualatin is excellent for Win9x gaming. It will work fine for the vast majority of games released before 2002. There may be one or two exceptions (like the aforementioned Deus Ex) which might not reach 60 FPS in the most demanding areas, but that's because those games are poorly optimized.
Reply 71 of 113, by Stryker1996
Joseph_Joestar wrote on 2022-06-15, 13:10:
If it can at least run halo that would be great
Reply 72 of 113, by The Serpent Rider
It's not that hard to run Halo, because everything is locked to 30 fps without interpolation.
Reply 73 of 113, by kitten.may.cry
Stryker1996 wrote on 2022-06-15, 13:16:
You can ALWAYS overclock said 1.4Ghz P3, probably easier to accomplish on the later boards.
Reply 74 of 113, by Stryker1996
kitten.may.cry wrote on 2022-06-15, 14:42:
Can I overclock it that far
Reply 75 of 113, by kitten.may.cry
Stryker1996 wrote on 2022-06-15, 14:45:
It would take a board without ISA, based on tests I've done.
Great overclocker!
Reply 76 of 113, by Stryker1996
kitten.may.cry wrote on 2022-06-15, 15:00:
Great overclocker!
So then what board would work best
Reply 77 of 113, by The Serpent Rider
You don't need much headroom when it comes to 1.4ghz CPU. 155-160 mhz FSB is possible on VIA boards, which is 1.6-1.7ghz limit for most Tualatins anyway..
Reply 78 of 113, by Stryker1996
The Serpent Rider wrote on 2022-06-15, 15:06:
I saw someone having one overclocked to 2ghz but I think you might need some extreme cooling
Reply 79 of 113, by kitten.may.cry
Stryker1996 wrote on 2022-06-15, 15:13:
https://www.youtube.com/watch?v=VHCHTbFhhqE
His chiller is very old school.
