First post, by mustagcoupe
I have a micron millennia pro or pro 2 with a w6li dual pentium pro motherboard. I accidentally botched a bios update, either the wrong file or something went wrong during the flash. Does anyone have the correct bios and know what i would need to do to flash it. The computer boots to a screen that says incorrect bios checksum or something like that. If i have to remove the flash chip does anyone know what equipment i would need to flash the chip directly. I broke the bios a while ago and the computer is currently buried so sorry about the lack of pictures.
Reply 1 of 11, by Horun
Did you flash a rev 02 board with rev 01 bios ?
The rev 01 bios is easy to find but will have to dig a bit to find the rev 02...
http://web.archive.org/web/19980120111930/htt … s/micmligh.html
added: technically it is a OEM Intel PR440FX motherboard from what I gather...OR a Micronics board:
http://web.archive.org/web/19970607130559/htt … ios/b-w6li.html
Need more information !!! 🤣
Reply 2 of 11, by mustagcoupe
I did not even know there was a rev 1 and rev 2 version. I had a very hard time finding any bios updates or information at all. Does it say on the board or how do i find it. If it wont boot past the bios checksum or similar screen is there anyway to do a bios update off a floppy disk or am i looking at programming the flash chip directly. I will dig it out and take a look and add some pictures when i get a chance.
Reply 3 of 11, by PC Hoarder Patrol
Horun wrote on 2022-06-16, 01:27:
Did you flash a rev 02 board with rev 01 bios ? The rev 01 bios is easy to find but will have to dig a bit to find the rev 02... […]
rev 02 is linked here (and attached) - https://www.driverguide.com/driver/detail.php … driverid=161732
The attachment W6LIS02.EXE is no longer available
Reply 4 of 11, by mustagcoupe
I dug it out from the corner it was buried in. I misremembered what happens when i turn it on. It boots to a black screen and makes 3 beeps repeatedly. I took some pictures of the board attached below. I did not see any rev 1 or rev 2 markings.
Reply 5 of 11, by Horun
Found the manual and other possible BIOS options here:
ftp://ftp.dyu.edu.tw/pub/Hardware/vendor/Diam … ics/PENTPRO/W6/
You probably need to remove the BIOS chip and use a TL866 type programmer...
Reply 6 of 11, by mustagcoupe
Horun wrote on 2022-06-18, 19:43:
Any particular recommendations on a programmer. And do you just load the .bin file or whatever format it is into the programmer and then solder the chip back on.
Reply 7 of 11, by bofh.fromhell
mustagcoupe wrote on 2022-06-18, 20:29:
Pretty much first hit with "tl866" on an (in)famous auction site.
Make sure you get one with a lot of adapters included, cause once you have this tool you keep finding uses for it =)
And yea, select chiptype, load rom and hit flash.
Tho there's a ton of options if you wanna get involved.
Reply 8 of 11, by mustagcoupe
Alright. Thats definitely something i can do. I will have to order the programmer when i get some spare cash. any chance this is one of those chips that can be programmed in circuit or will i have to desolder it.
Reply 9 of 11, by RussD
There is a method to update the BIOS. You need to create a special loopback parallel port dongle and a crisis diskette. Early in the boot process it checks for the dongle and if it sees one it will flash from the crisis diskette.
https://www.kontron.com/downloads/application … ash_sc_e113.pdf
Reply 10 of 11, by amijim
Hello vogoners, back in 2000 I had left some messages on sysopt with the procedure to complete a set up on micronics w6-li with win 2k. Today I set up again my trustful micronics. Vive retro computing and long live the 2cpu.
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 11 of 11, by amijim
If anyone needs some info do not hesitate to contact me.
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
