dosbox.conf lister
First post, by robertmo
https://www.ghisler.com/lister/
Just wondered if this could be added to dosbox as default dosbox.conf editor
Reply 1 of 4, by robertmo
or notepad++
also i guess it would be better if the file was called dosbox.ini in windows
as .conf is a linux thing
making it .ini in windows automatically opens it in lister and notepad with extra enhancements for .ini files (mostly menu)
.conf is opened as a plain .txt file in both aplications (and I guess all other windows file editors)
Reply 2 of 4, by dr_st
In Notepad++ you just need to select "INI file" once in the "Language" menu, and it will remember the setting.
Reply 3 of 4, by robertmo
for lister (inied) plugin of total commander you can just add the conf extension here:
Reply 4 of 4, by robertmo
and here it is for notepad++
in Settings
