First post, by assortedkingdede
- Newbie
I have been working on connecting case parts like lights to my motherboard but I am unsure if I am hooking them up properly. The manual for the case tells me to "always connect the colored wire to the pin 1 and the black wire to ground". I am unsure which is which because A . Some cables are white for ground instead of black and B. I do not understand which pin is ground and which is something else. I am genuinly worried about destroying something because I hooked something up the wrong way. I have attached a picture of the motherboard case pin header if that makes what I'm saying more understandable. Any info would help. Thank you!
