First post, by BEEN_Nath_58
I am playing some games that provide option for 16/24/32 bit colors. For all purposes, 16/32 bit colors just work fine but 24-bit colors, it just crashes the game. Is 24-bit color really unsupported? Isn't there any alternative ddraw.dll that supports it?
Reply 1 of 5, by leileilol
The last time i've seen a 24-bit color desktop mode was in the VLB days, so...
Debian's fucked
Reply 2 of 5, by darry
BEEN_Nath_58 wrote on 2022-06-19, 05:52:
This might do it.
https://github.com/elishacloud/dxwrapper
DdrawOverrideBitMode
This overrides the default bit mode. This requires either Dd7to9 or EnableDdrawWrapper option to be enabled.
EDIT : Then again, what would be the point ?
Unless you had a game that supported 24-bit but not 32-bit, of course.
Reply 3 of 5, by BEEN_Nath_58
darry wrote on 2022-06-19, 06:10:
This might do it. https://github.com/elishacloud/dxwrapper […]
This might do it.
I checked it's constituent wrappers but none of them seem to support 24-bit colors, the option is grayed out. I managed to gain 24-bit option access in this game with DxWnd but it just crashes. The only game that worked in 24-bit color, needing DxWnd was Icewind Dale 2
Reply 4 of 5, by Jo22
leileilol wrote on 2022-06-19, 06:09:
I second that.
Personally, I've seen it in the Windows 98SE days last time, I think.
But with Windows 95 era hardware. A Pentium 75 with integrated 2D graphics chip, I think.
Something like Cirrus or S3, maybe. Which was used in both VLB and PCI designs.
Edit: Now that I think of it, maybe some PC emulators/virtualizers had a 24-Bit limit, too.
Reply 5 of 5, by BEEN_Nath_58
I went to test Icewind Dale 2 on 16, 24, 32 bit colors. At first, I could see a clear difference in 16 and 24-bit colors, but when I compared 24 and 32-bit colors, they both looked completely same. So the game setting to use 24-bit color is setting 32-bit color in effect? I attached the photos of test, note that the sizes of the 24-bit and 32-bit files are quite same as well:
