First post, by keropi
Hiya!
I recently got a Soyo 4SA2 motherboard and I was wondering what the latest BIOS is for this mobo - and if anyone made a LBA48 HDD patch?
I found some BIOS files on retronn.de -> ftp.retronn.de/mirrors/www.elhvb.com_mobokive/Soyo/bios/486/
4sa-iob1.bin seems to be the latest official one from 1995
4sa0730.bin seems to be a 1997 one but no idea what was added/patched
If anyone knows more about it please reply , the board seems very nice.
ps.
I added the missing components so now the board has a working ps/2 mouseport - I just followed madowax's instructions 🤣
inductors and 47pf caps stolen from a dead ss7 mobo, added the extra 4.7k pullup resistors for the mouse data and clock lines and connected keyboard controller pin36 to the IRQ12 pin on an isa slot. The stock BIOS did not have mouse functions enabled so I used modbin but the later ones above have it enabled by default.
Everything with a pink dot was added to make the ps/2 header working, maybe it helps someone else to add the components:
I am now also wondering if removing D2 will prevent the battery from charging like it was with the 4SAW2 mobo - so I can just solder a CR2032 and call it a day....
Reply 1 of 19, by SteliosG
Hello Keropi and fellow Vogoners ! 😀
First post here !
I recently managed to find the same board and I also did the ps/2 mod , but without the pull up resistors . Can you please show me a picture of the place you added the resistors ? Are they there for safety ? I read something about current limiting . ???
Regarding the bios , I downloaded the pack from the vogons drivers site : http://www.vogonsdrivers.com/getfile.php?fileid=731
Inside the rar file there is a modded beta bios : 4SAW0911.BIN
I can understand the this bios is for the 4SAW , but as I have a programmer I decided to try it . This bios has support for PS/2 and also for LBA . I tried many HDDs up to 80GB and they are working as expected . I think the limit is 128GB
I'll also check the one from mobokive . I'm curious if it's faster/newer .
Now , about the battery . Yes , I also removed the old battery and replaced with a lithium one . You should remove the middle diode (D2) . I checked it with the multimeter and after removing it the 5v voltage is gone.
EDIT : Tried the bios from mobokive , but it doesn't support large HDDs . So , i am going back to the 4SAW0911.BIN
If someone could patch the other bios it could be awesome , as it has a few more options like tag bits ...
Reply 2 of 19, by keropi
thanks for the info on the battery situation, I will remove D2 as well 😀
I also tested the two newer 4SA2 BIOSes and can confirm large HDDs do not work with them.
Also noticed that both iob1 and 0730 consume more cpu usage when the ps/2 mouse is moving - seems something changed in IRQ handling? perhaps to help with win95 compatibility.
I tested for example PCPBENCH , normal 320x200 resolution:
BIOS IOA - originally came with my board
PCPBENCH VGA: 12.1
PCPBENCH VGA while constantly moving mouse: 11.8
BIOS IOB1 / 0730
PCPBENCH VGA: 12.8
PCPBENCH VGA while constantly moving mouse: 10.9
I am not sure I want to use the 4SAW bios on the mobo, have you used it long enough ? is it stable?
About the pullups, they are needed because the kb controller pins are open collectors. There are already 4.7K pullups for the keyboard so it makes sense to add them for the mouse as well.
Have a look at this zoomed picture , I used 0805 resistors that's why they are hard to see on the previous pic. R1 is a keyboard pullup so I used it's 5v side for the mouse pullups via a small cable:
full size: https://i.imgur.com/Ae863S4.jpg
Hope this helps!
Reply 3 of 19, by SteliosG
Thanks for the picture ! I just added the resistors . 😀
I got the board not many days ago and all I have done is to install Win98SE . I haven't done any test (benchmarks/stability/gaming).
Regarding the bios , for me it's more crucial to be able to use large HDDs . I'll do some search regarding the procedure of adding LBA support . 😀
Reply 4 of 19, by shock__
Any recommended values for the inductors? Just got myself a 4sa2 and it turns out to be a great board to be used with a POD100 (contrary to the PVI-486SP3 by Asus it runs absolutely stable and performs pretty much the same).
Current Project: new GUS PnP compatible soundcard
[Z?]
Reply 5 of 19, by kimschi
shock__ wrote on 2021-05-02, 14:04:
Hello,
ich have the same mainboard and was wondering, if someone could tell me the values ot the capacitators inductors sitting on L3 and L4 (to buy them), on my board both are missing. I get the "Keyboard error or keyboard not present" error message.
Maybe i'm totally wrong these are not needed an i have look into a different direction.
The board is booting up in general until this keyboard error message.
I would appreciate any answer.
The board is working again, the value is 10uH.
@keropi please could you linkt the tutorial for the ps/2 mod you are reffing ( I just followed madowax's instructions ), i'm planning to do the same.
Reply 7 of 19, by Chkcpu
mt777 wrote on 2022-06-21, 13:14:
does anyone recognized jumpers for am5x86? such beautiful mobo with 4x pci and 1mb cache and poor doc...
Looking at the user manual at https://www.ultimateretro.net/nl/motherboards/4718, I would use the AMD Enhanced 486DX4-100 jumper settings at page 15 and change jumper JP34 from 1-2 to 2-3. This should run the Am5x86-P75 at 133MHz (4x33) and L1 cache Write-Back mode.
Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 9 of 19, by mkarcher
Chadti99 wrote on 2022-09-24, 22:27:
Anyone had any luck running this board at 160 or 180MHz with an AM5x86?
For me, it works fine at 160MHz (4*40MHz). You need to add a third frequency jumper to be able to select FSB60, but experience at 180MHz (3*60MHz) was poor. It booted once with L2 set to write-through, I could get a cache/memory benchmark using ctcm (the c't cache measurement tool, not the Creative Configuration Manager, of course), but never was able to POST again at 180. I don't know whether it's the board or the chip, though. I went up to 3.6V, I think I even tried once at 4.0V, that didn't change anything. This makes it likely that the board doesn't really work stable at FSB60.
I did obtain DX4-120 in the meantime. If (but that's a big if) I get around to finally fix the 4SA2 for good (it has recurring issues caused by battery leakage), I will try 2*60 in that board, as I know that this processor works fine at 2*60. I tested that in a different board.
Reply 10 of 19, by Chadti99
mkarcher wrote on 2022-09-25, 07:34:
Great info, where is this missing 3rd jumper on the board? Looking at the manual you’d think J7 which is in line with JP21 and JP22 would be it.
Any issues with VLB Video?
Reply 11 of 19, by mkarcher
Chadti99 wrote on 2022-09-25, 09:16:
Only two "clock select" pins of the synthesizer chip are routed to jumpers. I added a third one next to JP21 and JP22, on the other side. I soldered it down to GND (available at that place) and ran a bodge wire to the third clock select pin. It's not just fitting a jumper into a position already present on the board. As I didn't glue down the jumper, the solder joint for GND broke and the jumper isn't "installed" anymore. As the 60MHz experience didn't work satisfactory, I didn't bother implementing a more permanent solution yet.
I'm quite sure I used an ISA graphics card for the 60MHz experiment, because FSB60 is finicky enough even without VL cards installed. But you should be aware that the most recent BIOS editions of the 4SA2 initialize the chipset in a wrong way, essentially disabling VL support. Many VL video cards still happen to work, but at an awful performance. The Sis496/7 chipset has a configuration bit that toggles a pair of pins between "request/grant" for a master-capable PCI slot or "LDEV/LRDY" for a VL slot. The latest BIOSes (like the one with 128GB support) set it to PCI req/gnt errorneously.
Reply 13 of 19, by mkarcher
Chadti99 wrote on 2022-11-02, 01:34:
Forgot to thank you for all the info mkarcher!
If you or anyone knows which jumpers control the cpu bus multiplier please let me know.
A 486 DX4 processor only uses a single jumper for the bus multiplier. The most common pinout (Intel DX4, Cyrix DX4, Cyrix 5x86, AMD Enhanced DX4 (SV8B), AMD 5x86) uses JP 43 (open = 3x, 1-2 = 2x for DX4, 4x for Am5x86). The old AMD DX4 (NV8T) used JP 34 (1-2 = 3x, 2-3 = 2x). That's from a scan of a 4SAW2 manual, not a 4SA2 manual. The scan of the 4SA2 manual I have is from an older revision and obviously wrong (it indicates the same jumper for old and new AMD DX4 processors). The CPU type jumpers seem to be identical between these board variants, so the scheme mentioned in the 4SAW2 manual should apply to the 4SA2, too.
Reply 14 of 19, by Chadti99
Thanks! Jumper 43 was it! I’m able to boot at 160MHz now. Unfortunately no luck posting at 200MHz(50x4) even on a known AM5x86 capable of posting at that speed. I def need to try the 60MHz FSB mod.
Reply 15 of 19, by mkarcher
Chadti99 wrote on 2022-11-02, 12:18:
Don't forget that you can adjust the core voltage! That's JP39: 1-2 = 4V, 3-4 = 3.45V, 5-6 = 3.6V. It's quite likely that you Am5x86 needs to get at least 3.6V to POST at 200MHz.
Reply 16 of 19, by Chadti99
You were exactly right, I needed 3.6v to post, was even able to finish a Quake Timedemo! Now to determine why l2 cache isn’t working. Just can’t seem to get past “updating ESCD” with any combination of L2 enabled. At any clock speed.
*swapped in a different memory module and I think l2 is good!
Reply 17 of 19, by mkarcher
Chadti99 wrote on 2022-11-02, 23:17:
Are you talking about the PS/2 memory module? Avoid EDO modules, unless you specifically know that both the BIOS and the exact revision of the chipset on your board are EDO compatible (applies to both the SiS 496 and the UMC8881). Strange things can happen with EDO modules in older mainboards.
Reply 18 of 19, by Chadti99
Yah just a dram module, I don’t keep good track of which modules are EDO vs FPM. I think you are exactly right though, it was probably an EDO module causing issues. I need to sort my stash into two boxes.
I also got VLB video working with an older bios version from 96. I really like the flexibility of this board although a 60MHz FSB option would of been nice.
Reply 19 of 19, by watson
Has anybody tried fixing the latest bios revision (WA0911) to work properly with VLB cards?
I got this board in very poor condition and without a BIOS chip.
My board does not start with slightly older BIOS version WA53 - it gets stuck on POST code BE ("Chipset default initialization; Program chipset registers and power-on BIOS defaults").
With the latest BIOS, everything works perfectly(*) with PCI graphics, but VLB is basically unusable as previously stated. I even get corruption in DOS.
Without working VLB, it's just another SiS 496/497 board. Nice but nothing spectacular. However, I am very happy that I got it to work.
(*) I had to replace the electrolytic capacitors because the board was unstable with 3.3 V CPUs. I did not think it would make a difference because it's a linear regulator, but recapping absolutely fixed it.
