Help! PC won't power on with Slotket
Reply 41 of 78, by Grem Five
PARKE wrote on 2022-06-25, 21:49:
Grem Five wrote on 2022-06-25, 16:50:
Well this is helping me I'm learning what brand some of my slotkets are. I'm tempted to post pics of all of them.
Vogons member Luckybob has made available a compilation of slotket info here:
https://drive.google.com/file/d/1kGgO3TJyFDTH … y4wVj4GJBY/view
Awesome thank you for pointing that out and double thank you to @luckybob for doing this.
Reply 43 of 78, by rootinit
Wow, that's a lot of great info. Thanks.
IBM ThinkPad 755Cs (Win 3.11) • IBM ThinkPad 365x (Win 98SE) • IBM ThinkPad TransNote (Win 2k)
IBM PC (PC DOS 3.30) • IBM PS/2 Model 80 (Win 3.11) • IBM PC 300GL (Win 98SE)
AT&T PC 6300 (MS-DOS 6.22) • Dell XPS T550 (Win 98SE)
Reply 44 of 78, by Grem Five
I'm not sure if its suppose to be missing pictures but seems to be missing some on page 61-64. I dont know I saved the pdf to my system.
Reply 45 of 78, by rootinit
Sphere478 wrote on 2022-06-24, 18:24:
I may have your answer, […]
At some point they added two pins that keep the cpus from working in older mobos. As well as a second reset pin and moved power good pin. (Little rusty on specifics but something like that) I have been compiling info about mods for these and other issues in this thread:
Socket 370 Tweaker
I forget if Coppermine had this, I think maybe, tualitin definitely did.
If I had to guess I’d say your cpu is probably being held in reset.
I think this only applies to the Coppermine T and Tualatin processors. This one is neither.
Reply 46 of 78, by Grem Five
Definitely interesting... I have 1 ASUS that isnt on that link of Luckybob and the:
AA370P (marketed as Matrix & Evercool) 370CPU rev 1.0
FCPGA Coppermine / 133 / auto voltage / no voltage clamp
on page 3 I tested last night and have marked Celeron Slotket as I only got a celeron to work on it and not the coppermine cpu on the Dell Board.
Edit: NM I found the ASUS one I got on page 61: Asus S370-L PPGA Celeron / 66
Reply 47 of 78, by PARKE
Sphere478 wrote on 2022-06-25, 22:30:
Someone on a computer should zip that and host it here in case the link ever goes dead.
There may be a problem with the copyright of a substantial number of photo's that were 'found' on the interweb including on commercial websites. But as long as I am around you can send me a pm with your email address and I can link you to the latest copy that is stored on Dropbox.
Reply 48 of 78, by PARKE
Grem Five wrote on 2022-06-25, 22:48:
There are (at least) two versions of the AA370. The ones with 1999 datemarks on the rear side do typically have a sticker with [AA370E] marking and support Mendocino Celerons. The ones with 2000 datemarks on the rear side do typically have a sticker with [AA370P] marking and support Coppermines.
Does any of this info fit your version ?
The attachment sticker1.jpg is no longer available
Reply 49 of 78, by PARKE
rootinit wrote on 2022-06-25, 18:43:
Basically, my main concern as of now, is finding a replacement slotket that I can try on the IBM. Does anyone know where I could purchase a Coppermine compatible slotket that might work here? I definitely appreciate the different reports right now, but unfortunately not sure how I could proceed otherwise.
When you combine three different brands like as in your case it is sometimes a matter of hit and miss.
There is maybe nothing wrong with your Abit slotket and it may work perfectly on Abit motherboards. Intel tested the Abit slotket revision 0.82 on BE6-II, BF6 and BX6 2.0 in summer 2000 and 'approved' it.
Your cpu may be the culprit and/or your IBM bios does not 'like' the combination that you offer it.
Up to a couple of months ago I saw branded coppermine slotkets for reasonable prices on the japanese Yahoo auction site regularly but we cannot visit that site from Europe anymore:
https://page.auctions.yahoo.co.jp/jp/auction/q441731498
Reply 50 of 78, by Grem Five
PARKE wrote on 2022-06-26, 07:55:
There are (at least) two versions of the AA370. The ones with 1999 datemarks on the rear side do typically have a sticker with [ […]
I retested it yesterday and it works with coppermines, for some reason it doesnt always work with the 1 Ghz processor I have pictured in my 2 slotkets earlier in the thread. After I saw that list and that it should run coppermines I tried a few other processors in it, why its hit or miss with that SL5QV is beyond me.
Reply 51 of 78, by PARKE
Grem Five wrote on 2022-06-26, 11:58:
It does not seem a very 'high end' product (basically it is just a modded Celeron slotket) and at that frequency performance may suffer. If you had the same problem with a more advanced model you could up the voltage a bit.
Reply 52 of 78, by rootinit
Slotket was definitely the issue with it not powering-on. I found someone who was local that sold me a Shuttle HOT-C003 rev. 3.2 (aka AZZA 370 CPU Card). Now it boots, but the weird issue is that there is no L2 cache being reported in the BIOS. I can boot after getting an error, but it is extremely slow. It seems that the cache is really not working.
I had this same issue with an 850 MHz Slot 1 256KB/100/1.65v (SL43F), but returned the item to the seller thinking it was a faulty CPU.
Any ideas about how should I proceed?
The attachment IMG_20220627_203256008.jpg is no longer available
The attachment IMG_20220627_203309609.jpg is no longer available
The attachment IMG_20220627_203325215.jpg is no longer available
Reply 53 of 78, by Sphere478
rootinit wrote on 2022-06-28, 01:42:
Slotket was definitely the issue with it not powering-on. I found someone who was local that sold me a Shuttle HOT-C003 rev. 3. […]
try a bios update?
btw, I encourage you to track down the difference between those two slockets so we can know what needs to be modded in the future. 😀
Sphere's PCB projects.
Reply 54 of 78, by rootinit
Sphere478 wrote on 2022-06-28, 02:46:
try a bios update?
BIOS is already at the latest. I'd love to track down the differences, but I'm quite lacking in electrical engineering knowledge.
Reply 55 of 78, by rootinit
Another weird thing is that I put in a SL4C8, which is also a socket 370 1 GHz PIII, but this one only has a multiplier of 7.5 with a FSB of 133 to achieve this. I thought it'd be reported as a 750MHz in the BIOS (this machine only has 100MHz FSB), but it shows as the full 1 GHz. Maybe the slotket is doing some trickery? Either way, it still has 0KB of L2 cache for some reason. I have another PIII CPU coming in for testing soon: SL4CC 850MHz/256KB/100MHz.
Reply 56 of 78, by PC Hoarder Patrol
rootinit wrote on 2022-06-28, 05:49:
Progress at least 😀
Assuming they were ever designed for them, maybe the BIOS detection routines are struggling to identify cpu type / features and are just 'best guessing' instead - 0KB cache might imply it thinks Celeron?? and the 133MHz FSB maybe just parroting what the cpu / sloket combo is reporting?? - what does a program like HWINFO report (also try SPEEDSYS / DOSBENCH if you have them)
https://www.hwinfo.com/files/HWINF620.ZIP
Reply 57 of 78, by rootinit
Thanks for checking back with me. Here are what some of these sort of utilities are showing.
Reply 58 of 78, by rootinit
I also installed Powerleap CPU Control in Windows, and saw that it incorrectly identified it as a Coppermine-T (probably because this one shares the same CPUID as some Coppermine-Ts). I tried to force enable the cache in this utility, but it just blue screened, and made it inoperable.
The attachment powerleap-cpu-control-1.jpg is no longer available
The attachment powerleap-cpu-control-2.jpg is no longer available
Reply 59 of 78, by smtkr
Thanks for that. That's a great resource.
I have a Slot-T, which I think is probably the only slotket I'll ever need. But I saw an ebay seller offering a few of the Abit Slotket !!!s NOS like the OP showed so I picked one up last month just to have. I'll probably try it out some day when I get time, but the comments here have lowered my expectations.
