post up pics of your "computing area"
Reply 1980 of 2393, by appiah4
Kahenraz wrote on 2022-06-27, 22:34:
This is not what I had pictured in my mind after reading that you had setup for a LAN part in your "outhouse".
My sentiments exactly.. These photos ruined my dreams of playing Quake 3 with friends on a LAN while taking a dump.
Reply 1981 of 2393, by gerry
RetroHamer wrote on 2022-06-27, 18:13:
Slowly setting up my outhouse for a LAN party with some friends over next few months. Everything from K6 233 and Pentium 2 500 upto I7 3770 and Ryzen 2200G.
Need more monitors and Chairs but they'll be easy to get.
great stuff, will be good to post pic when its all running too.
Reply 1982 of 2393, by RetroHamer
gerry wrote on 2022-06-28, 07:01:
Will do. Building up the systems now so they hopefully all work together on a network
Reply 1985 of 2393, by RetroHamer
Networking has started. Some Doom 2 and Half life to test.
PII 500 Voodoo 2 8MB sli and K6 266 Mach64 vt
Reply 1986 of 2393, by gerry
RetroHamer wrote on 2022-07-03, 13:20:
this is looking great 😀
Reply 1987 of 2393, by tylerjanebr
Still a work in progress, but I wanted to have an area in my basement with computers for the three primary generations of windows that I grew up with: 3.11, 98, and XP. I still want to do better cable management, get some better seating, and maybe get new desks for them. But I like where it's at so far.
Right is a 486 DX2 66, middle is a 1.0ghz Pentium 3 with a Radeon 9800 pro, left is a Core2Duo E6600 with a GTX 470.
Reply 1988 of 2393, by pan069
tylerjanebr wrote on 2022-07-21, 14:56:
That Iiyama in the middle, nice! Used to have one like that, sad I had to dump it when moving countries. Which model is that?
Reply 1989 of 2393, by MarkP
Looking good everyone.
Reply 1990 of 2393, by Meatball
Reply 1991 of 2393, by tylerjanebr
pan069 wrote on 2022-07-21, 22:05:
That Iiyama in the middle...Which model is that?
S901GT, "Vision Master 450". It's excellent but it might be near the end of it's life. About every ten minutes, it "ticks" and flickers and degausses and then comes back to life. Still entirely usable and looks great.
Reply 1992 of 2393, by chrismeyer6
tylerjanebr wrote on 2022-07-22, 17:58:
It's possible that it just needs a recaping and be good for a long while more.
Reply 1993 of 2393, by creepingnet
Here's my current setup....
The attachment desk.jpg is no longer available
The desk is where I swap out my modern and vintage machines periodically (obviously). Right now the 2015 iMac and Tandy 1000A are setup as I'm recording Tandy youtubes at the moment and I've been learning the Apple ecosystem as I use it at work (and because I do use Garageband for music sometimes, and the Mac seems quite good for recoreding in BandLab - that's what the Line6HD500 processor under the desk is for).
The attachment laptoprack.jpg is no longer available
The Laptop rack is where the laptops are when I'm not using them, so they get showed off. On top of the rack is my DFI MediaBook 486DX2 (basically a rebadged NanTan 9200M), a BSi (NanTan) FMA3500C, the NEC Versa 40EC, NEC Versa V/50, and the NEC Versa P/75 at the bottom. My NEC Versa M/75 is next to it because that's the one out of the lot I probably use the most.
The attachment storage.jpg is no longer available
This is "holding" for other systems. On the top rack we have the broken Versadock which I might be cannibalizing soon. Next to that is the Blue Lightning Compaq Deskpro 386s/20. The second shelf is my 17" Dell CRT Monitor and 14" Micron CRT with the awful stain on top. On the bottom is my main 486DX4-100 system, and 2 other PC's in the next photo. Also on top is the "Beige Beast" InWin D500 mATX desktop that runs Linux.
The attachment storage2.jpg is no longer available
Bottom of the shelf Left to Right - 486 DX4-100 main with the monitor on top (14" SVGA KDS I believe), next to that is the Moondog 486 DX4-100 tower with the digital readout, and next to that is my Dell Precision T5400 Linux Mint machine.
~The Creeping Network~
Reply 1994 of 2393, by Irinikus
Here's my current setup: (Spread across two locations!)
There are currently not that many PC's around, but I do hope to change that soon!
YouTube
Reply 1995 of 2393, by chrismeyer6
Irinikus wrote on 2022-10-07, 10:40:
Here's my current setup: (Spread across two locations!) […]
Awesome setup I'm loving all the SGI and Sun systems.
Reply 1997 of 2393, by Standard Def Steve
My favourite spot for fall DOS gaming is right under this Ohio Buckeye, especially on a holiday morning like today. I always get a kind of neat feeling bringing out a mug of cocoa & playing DOS games out here as the sun rises. This morning, the tree happened to shed half its weight; the golden leaves gently landing on me, my keyboard, and the laptop screen just made playing The Legend of Kyrandia an almost surreal experience!
"A little sign-in here, a touch of WiFi there..."
Reply 1998 of 2393, by chrismeyer6
Standard Def Steve wrote on 2022-10-10, 18:48:
My favourite spot for fall DOS gaming is right under this Ohio Buckeye, especially on a holiday morning like today. I always get […]
Now that is a perfect back drop for some DOS gaming. You have quite the beautiful yard.
Reply 1999 of 2393, by buckeye
That is a sweet spot, from one "buckeye" to another. I'm in Bama these days tho but still migrate up north
to see family couple times a year.
