First post, by Mitsuke
I got a EPoX EP-D3VA Dual Pentium III motherboard today. I always wanted to experiment with dual P3's so why not, I went ahead and bought it for fairly cheap.
Sadly, it does not seem to work. It turns on but I get nothing on the screen. I have no speaker so I have no idea if its throwing some error code or not. I tried with different RAM modules as well as different AGP cards and still nothing. CPU, chassis and GPU fans spin and the keyboard lights up for a few seconds. Pressing NUM LOCK does nothing.
I have no idea what else to try. I think its dead.
Could I have killed the motherboard while installing it?
Reply 1 of 4, by paradigital
Have you got a POST test card? That’d be my first port of call. Also are you using two CPUs or just one? If the latter which socket?
Reply 2 of 4, by bofh.fromhell
Start with adding the PC speaker.
Without hearing any errors its gonna be really hard figuring out whats preventing POST.
Reply 3 of 4, by BitWrangler
Any life if there's nothing in the keyboard socket? (no keyboard, no adapter)
Fresh CMOS battery?
CMOS jumper not in "shipping" position? (some boards have that, basically disconnects it so it doesn't run down)
8 month old chicken born on a full moon and scrying dagger on hand for advanced diagnostics?
Reply 4 of 4, by PD2JK
Maybe a BIOS flash procedure has gone bad by the previous owner, but first things first and see above.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
