HP Kayak XU
Reply 20 of 35, by gdjacobs
Intel486dx33 wrote:
It‘s true. And a red led light when the sad face is displayed. Maybe it was designed to be friendly to people with hearing disab […]
Maybe it was designed to be friendly to people with hearing disabilities. ( deaf ).
Or when in a loud place or a place with allot of noise or when someone has headphones on.
That would make sense since this computer runs loud with all the fans going.
Meant to evoke an association with PA-RISC gear?
Reply 21 of 35, by Intel486dx33
GordonFreeman wrote:
Huh... interesting. Could you show a picture of what it looks like normally when the system is running?
It’s stored deep in my garage right now and I am to lazy to take it out.
Sorry. It’s winter, raining, and cold right now. Maybe in the summer.
Reply 22 of 35, by Intel486dx33
Errius wrote:
This looks like a workstation version of the Netserver LC3, though the LC3 lacks an AGP port. (The Netserver E60 has an AGP port, but lacks VRM slots.)
Kind of, these where in service at the same time as the Netserver LC.
They are both loud computers that run NT4.0
Reply 23 of 35, by Intel486dx33
Arctic wrote:
Do you still have the CPU fan and shroud for it?
Could you take a picture of them?
Thank you 😀
If you need a fan shroud and cpu duct ( parts 89a and 89b ) . I would forget about trying to 3D print one.
Just add a fan to the rear of case and add heat sinks with fans to you cpu’s.
Blow the air out the back of the case.
Reply 24 of 35, by Intel486dx33
My HP Kayak motherboards are made in Singapore and Malaysia.
HP use to have really great warranty support if anything ever went wrong with these computers all I had to do was call there customer support and they would ship me out a new part with out question.
No questions asked.
That’s why I really liked HP computers. Great support.
Reply 25 of 35, by wanzerr
Intel486dx33 wrote on 2019-03-05, 19:47:
My HP Kayak motherboards are made in Singapore and Malaysia. […]
HP use to have really great warranty support if anything ever went wrong with these computers all I had to do was call there customer support and they would ship me out a new part with out prejudice.
No questions asked.
Trying to resurrect this thread, having a CPU socket post error 0401 on my recently cleaned and reassembled Kayak XU. The single VRM module doesn't appear damaged and the Pentium II slotted back in with no dust or apparent damage. Any ideas? Haven't been able to successfully google a post code or beep code chart, and physically checking the connections is no dice.
Reply 26 of 35, by PC Hoarder Patrol
wanzerr wrote on 2022-07-04, 17:37:
No questions asked.
Welcome to Vogons 😀
That's listed in the HW monitoring manual as - 0401h CD-ROM not detected (but configured in CMOS) CD-ROM Error
The attachment Manual.pdf is no longer available
Reply 27 of 35, by wanzerr
PC Hoarder Patrol wrote on 2022-07-04, 23:57:
Welcome to Vogons :) […]
No questions asked.
Welcome to Vogons 😀
Manual.pdf
Thanks for the heads up! Had to re-insert the extra CPU spacer card in the second slot, and installed two 256MB ECC dimms, running like a champ. Will likely start a new thread with all the specs.
Reply 28 of 35, by wanzerr
Anyone knowledgeable about Soundblaster and Kayaks? I've fiddled with reserved memory access and IRQ settings until I'm about to throw my kayak in the river 😀
Soundblaster CT4740, Kayak XU6/450, Windows 2000 Service Pack 4, 768MB RAM, having no success whatsoever getting Device Manager to recognize install and use my sound card. It always says there is a hardware conflict even when there is not. I've tried letting the BIOS auto assign, I've tried manually, nothing ever takes.
Any ideas out there?
Reply 29 of 35, by Intel486dx33
Might work with a PCI Sound Blaster Live or Audigy 2zs ?
I have never been able to get it to work with anything other than onboard audio.
Reply 30 of 35, by Dwaco
Did you disable onboard audio in BIOS?
CT4740 is a PCI card I understand, with Ensoniq lineage.
What is your model number?
P.S. Don't you dare to throw Kayak in the river. We would never speak to you again.
PC: HP Kayak XU800 [2x PIII 1Ghz, 512 Mb RAM, Voodoo3 3000, SB Audigy Platinum EX]
Sparc: Blade 1000 [2x US-III, 3Gb RAM, 2x 73Gb FC-AL 10k, XVR-1000], Blade 100
PA-RISC: HP C3750 [FX10Pro]
Sony F1XDJ, A1200, C128
Reply 31 of 35, by wanzerr
I gave up and just pulled it out and am enjoying the onboard audio 😀
Tried to give Deus Ex and Mechwarrior 4 a good run with it and it just got too laggy; probably needs a good pick of GPU drivers as well- back to Wine/Proton + Linux on the modern system for my retro fix.
Reply 32 of 35, by Intel486dx33
I don’t remember doing much gaming on my Kayak as I mostly ran WinNT 4.0
But later I upgraded to Win2000.
I Mainly used a Dual head AGP Matrox G400.
But I remember experimenting with a Voodoo Banshee and TNT card
I think I tried an Ensonic sound card too and sound blaster with NO success.
So yeah, I ended just using the onboard audio with the Matrox G400 and Win2000 with Two Sony 20-inch Monitors
Reply 33 of 35, by wanzerr
I have ordered a second 450MHz Pentium II as well as found a part supplier for new old stock VRMs - will update with pics when parts arrive.
Anyone had any luck putting a modern PSU inside? My factory original one seems fine but I don't want to tempt fate.
Reply 34 of 35, by Intel486dx33
I have 3 of them in my garage I have not used in years.
Too heavy to take out. And I am to Lazy and don’t have room to set them up.
But they served me well for Work for many years. WinNT 4.0 thru Win2000
Reply 35 of 35, by Intel486dx33
I found some more photos.
This was the Best most reliable, dependable, stable computer I had from Windows 98 thru Windows 2000
When a component broke HP would send me out a replacement ASAP.
As long as the computer was still under service contract.
