Reply 22280 of 29597, by mbbrutman
creepingnet wrote on 2022-07-26, 07:12:Pulled out the Tandy to start recording some footage for #SEPTandy this year.....christ....all sorts of issues... […]
- Most of the bigger games are corrupted and refuse to run
- having issues copying over files using mTCP (file corruption)
- Now looking around at working 8088 compatible pkunzip tool so I can copy ZIPs over and unzip them on the PC (more reliable in general)
If you think mTCP is causing the corruption I'd like to hear about it. I think it's unlikely and it usually turns out to be a hardware problem, but you never know.
The data is checksummed before it is transmitted, and the checksum is confirmed when it is received. Ethernet also protects the packets with a 32 bit CRC. If something is corrupted it is happening either before the data checksum is computed at the source, or after it is received and verified by the receiver.
I would start running memory testers on both machines.
