Regressive bugs - report them here
Reply 40 of 175, by Dege
Thief2 Metal Age? I have a version with a D3D9 renderer but I can't see any difference between 2.77 and 2.79. Do you have the original version (D3D7 or sg like that) of the game?
Reply 41 of 175, by Dege
Could you give me a savegame (or a complete profile data) plz? I cannot find that point, if I think it right, it's somewhere in the Canyon part of Geonosis. I also cannot find any other place amongst my savegames where the skybox is so visible.
I already found a bug with SW RepCommando but this should be another one.
Reply 42 of 175, by lowenz
It's in front of Sun Fac "war room" but you can see the problem at every "window" 😁 in the second levels of Geonosis (just when you complete the squad).
Reply 43 of 175, by lowenz
Save file here in attachment!
Reply 44 of 175, by Dege
(I moved the related posts here because it's a regressive bug)
Ok, thanks, but I found it meanwhile. Indeed. This bug is the same that I also stumbled upon and fixed (flashing textures on environmental objects like rock-walls).
I'll release a WIP with the fixes, till then you can disable 'DirectXExt\EnableSpecializedShaders' with an older version as a workaround solution.
Reply 45 of 175, by BEEN_Nath_58
Dege wrote on 2022-07-12, 12:02:
Yes I am using the D3D7 version of the game on Windows 11. The screenshots show the missing stars in the sky.
v2.05.77
file.php?mode=view&id=141320
v2.05.79
file.php?mode=view&id=141321
Reply 46 of 175, by Dege
I installed the original version of the game (version 1.07 I think) but the sky texture was there with 2.79. The game could be patched to 1.18 if I got it right but anything else higher is D3D9(?).
Reply 47 of 175, by BEEN_Nath_58
Dege wrote on 2022-07-13, 12:06:
I use 1.18 as well, the newer versions are newer engines so they change the architecture.
The stars appeared why the Sky Detail was set to low, it appeared very blurry.
Reply 48 of 175, by Crosshair
Hello, I'm looking for help. The nvidia driver has stopped supporting 32bits for a while, so it seems due to that I can't use my nvidia card for the DGVoodoo 2 to run games like MechWarrior 3, I've been looking for possible solutions and found some Linux users that somehow bypassed that problem... but since I'm a windows user I can't understand what they've done, and now I'm stuck
Reply 49 of 175, by BEEN_Nath_58
Crosshair wrote on 2022-07-15, 07:53:
I am confused, do you mean 32-bit colors? 32-bit color is still the standard and the common norm and is still supported.
Reply 52 of 175, by WhiteBear
Midtown Madness graphics flickering since the new dgVoodoo 2.79.1 version with OpenMM1. Version 2.78.2 works fine with OpenMM1.
Reply 53 of 175, by FulValBot
And in Midtown Madness smokes are still missing
Reply 54 of 175, by v00d00m4n
Recent versions of dgv are very slow in Oddworld 1 & 2 (Odyssey and Exodus), both are ddraw, i get like 1 fps during fmvs and menus. Same behavior happens with few other ddraw game, cant remember which few, but seems like cause is the same. So most likely fixing Abe would fix other ddraw games.
I use steam versions of these games:
https://store.steampowered.com/sub/6951/
For now i have to use update CNC DDraw, as is has no such issue, but i has its own issues and i prefer dgv in general, so it would be nice if this slowdown will be fixed.
Update: i just tested this again with most recent DGV
It seems that setting scaling mode from unspecified to any stretched mode or setting any forced resolution causes this slow motion, if you keep uspecified and let game render in native 640x480 res it works fine. So slow down happens when FMV and menu got rendered in upscaled mode.
Reply 55 of 175, by Dege
Actually I can't see any difference compared to older versions. For FMV's you have to enable DirectXExt\PrimarySurfaceBatchedUpdate and it runs fine.
Reply 56 of 175, by StenApp
2.79_2 didn't work for Tony Hawk Pro Skater 2, it showed no textures.
Could it be a AMD driver problem since i'm having a Radeon Pro 560? How can i test if it's the driver or a dgVoodoo bug?
"Please don't report the most annoying one: D3D11 is broken with AMD drivers as of dgVoodoo 2.55. I'm aware of that and cannot do much about that."
2.51 works fine...
Reply 57 of 175, by BEEN_Nath_58
StenApp wrote on 2022-09-02, 22:54:
Hi, […]
2.51 works fine...
Try D3D12 renderer
Reply 58 of 175, by StenApp
Try D3D12 renderer
That did the trick, thank you!
Reply 59 of 175, by chiangl2943
Hi, my english is not very good, but i try to explain my problem with google translate
The game I play is the old game "TalesWeaver"
I originally used the dgvoodoo2 ddraw.dll version 2.7.3 and could play the game slightly smoother
But when I try to use a newer version of ddraw.ll, like version 2.79.3
My game has black flickering
Is there a way to fix this please?
What information do I need to provide to allow the author to confirm this issue?
Screen demo:
https://www.youtube.com/watch?v=xWppG5TeGD0
