That 12nS TAG schip was probably fit in by the same guy who screwed the screw of the heatsink - or 12nS 8Kx8 chips were cheaper / better available.
Later revisions of this BIOSTAR board with burst-SRAM had 15nS TAG chips (the Samsung "-13" chips are 7nS):
The attachment 8500TACv6.JPG is no longer available
Glad you picked a 430FX board.
The INTEL application notes have all the info about the timings:
The attachment 430FX_timings.JPG is no longer available
At no frequency are the TAG timings faster than the cache timings. They are slower and @ 66MHz equal.
(Same goes for the Burst SRAM case: All TAG timings are significantly slower.)
Here´s the full datasheet:
http://13.124.15.139/pdf/download.php?id=fd4b … =P&term=82437FX
___________________________________
Just for the record here´s another example, where TAG-RAM seems to be faster than cache-SRAM:
The attachment 12_15_cache1.JPG is no longer available
While the cache SRAMS do have 15nS read and write cycles, the TAG-chip - despite having "-12" in the name does in fact have 120nS read and write cycles!
