Biostar M6TZA and PIII-800MHz
Reply 20 of 35, by PARKE
600MHz slot 1 on a Biostar M6TZA is not that bad.
Reply 21 of 35, by haker120
I have 500MHz modified (?) P2 processor that is present as PIII 500MHz. I mean there is sticker from P3 but I've read it's more P2 than P3.
Reply 22 of 35, by AlexZ
Get a Katmai 600Mhz for a 20% speed upgrade. That's the least you can do without risking anything. My PIII 900Mhz is mostly useful for late games like Return to castle wolfenstein, Fifa 2003, Nhl 2003.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 23 of 35, by haker120
Thanks, I'm not sure I'll upgrade this particual PC this way but surely 600MHz sounds better. What should I buy? It's a complete slot1 processor or s370?
Reply 24 of 35, by dionb
haker120 wrote on 2022-08-09, 19:01:
Katmai is Slot 1 only (as it has external cache chips). Note that there are four (!) versions of 600MHz P3. The only one that should work regardless, is the Katmai 100MHz FSB version. The P6-300B is Katmai 133MHz, which your board can't support (it will run at 450MHz), the P3-600E is Coppermine, so newer core with unsupported voltage, the P3-600EB is both Coppermine and 133MHz FSB. Check the S-spec of any CPU you are considering. If it has 512kB L2 cache and is designed for 100MHz, it's the one referred to.
Reply 25 of 35, by smtkr
It's kind of crazy that coppermine slotkets cost more than a socket 370 motherboard.
Reply 26 of 35, by dionb
smtkr wrote on 2022-08-10, 03:56:
Upgrade stuff almost always ends up costing more than regular things, because so many people want to put max possible on their boards.
That said, I don't think they're that expensive - the most expensive on eBay cost more than the cheapest motherboards, but if you compare a iWill Slocket-II on eBay with an Asus CUBX on eBay, I suspect the CUBX will still cost a lot more 😉 Being more creative with search terms I'm seeing a lot of 7 slockets with at least one CuMine-capable one for half the price of the iWill, and locally I'm seeing a nice MSI MS-6905 1.1 for EUR 25. Not completely free anymore, but by no means insane. Yet.
Reply 27 of 35, by haker120
But do I lose anything? This build has Voodoo 2 SLI 16MB and GeForce 4 4200. 😀
Reply 28 of 35, by matze79
PARKE wrote on 2022-08-09, 14:51:
The 370SP 2.0 photos that I have come across are all from around week 40 of 1999 and as far as I have seen these are all Mendocino dedicated. If they were able to run Coppermines out of the box they would not need this mod:
Slotkets have become expensive enough attract scam artists, or so it seems.
This mod will also not work in all mainboards and may cause instabilities.
Its only a "Half Mod"
Reply 29 of 35, by PARKE
haker120 wrote on 2022-08-10, 09:34:
The fps of the Voodoo SLI may increase by +/-5% when you upgrade to 600/700 Mhz.
The Gf4 ti 4200 is seriously underpowered in combination with such a cpu - it starts to shine a bit above 1HGz and up.
Reply 30 of 35, by dionb
PARKE wrote on 2022-08-10, 14:46:
Second that. I have a V2 SLI + Ti4200 with P3-1400S and definitely feel CPU limited there too.
Reply 31 of 35, by haker120
So what about Voodoo 3500 with P3 1GHz?
Reply 32 of 35, by PARKE
That combination is better balanced; the sweetspot of the V3 3500 sits around +/-800MHz - in my experience slightly higher than the V2 SLI.
Reply 33 of 35, by haker120
So I don't have stronger P3 for V2 SLI + GF4 Ti 4200 and I'm glad V3 build is rather ok. 😁
Reply 34 of 35, by PARKE
I am not sure if there are disadvantages of running a TI 4200 on an early PIII cpu but many folks here combine that sort of cpu with Geforce 2 MX 400 or Geforce 4 MX 440 which is more in balance. They are readily available and relatively cheap. The TI 4200 belongs in a more powerful system but it is in the end a matter of taste. When it works for you, it works.
Reply 35 of 35, by haker120
Well, it does and I'm glad it runs all games I want smoothly. 😀
