Reply 40 of 56, by Kekkula
Does anyone know if X-fi fatality edition bracket is compatible with sb live! card?
X-fi original cable won't fit but i could use standard ide cable instead.
Reply 42 of 56, by Kekkula
Thanks.
So it seems that they are not indeed compatible 🙁.
And I think X-fi is not compatible with windows 98.
Reply 43 of 56, by DerBaum
Kekkula wrote on 2022-08-25, 07:55:
Thanks.
Get a Live! Drive IR and put on the faceplate of a X-Fi Drive.
Or get a Audigy 2 or 2ZS wich have the connector needed for X-Fi drives.
FCKGW-RHQQ2
Reply 44 of 56, by RaiderOfLostVoodoo
No it's not.
Audigy is the last with official driver support.
But there are are modified drivers for Audigy 2.
So the Audigy 2 ZS Platinum Pro is the last one you can use in Win98.
Reply 45 of 56, by Joseph_Joestar
RaiderOfLostVoodoo wrote on 2022-08-25, 13:03:
Both the regular Audigy 2 and the ZS version have Win98 drivers on the official install CD.
There is no need to make any modifications to get this working. Just pop the CD in and follow the instructions on the screen.
My retro stuff
Reply 46 of 56, by RaiderOfLostVoodoo
Oh really? I thought you'll need modified drivers.
Good to know.
Reply 47 of 56, by jaskamakkara
Intel486dx33 wrote on 2019-04-03, 05:49:
more photos:
Sorry to resurrect this thread, but what is the digital i/o card being referred to here? I can't find it anywhere. I found a CT4770 device but that doesn't look like it has optical out on it. I would love to find one of these simply for the optical out. If anyone has one that they are willing to sell then please contact me.
Thanks!
Reply 48 of 56, by Mr.Hunt
jaskamakkara wrote on 2024-03-13, 19:54:
more photos:
Thanks!
Try to find on Aliexpress or another shop "SPDIF out bracket", you will find something like this:
You must connect to pin 29, pin 30 and +5v on pin 1
Reply 50 of 56, by Mr.Hunt
If any one interested, you can find some information on site https://sblive.narod.ru/ You can use google translator or yandex translator.
Reply 51 of 56, by zuldan
Went through my box of stuff and came across this CT4770. Anyone tried this card? I'm guessing you just use a standard 40 pin ribbon cable to the Live card. I wonder if the midi out would work in DOS?
The attachment 1.jpg is no longer available
The attachment 2.jpg is no longer available
fyi, if anyone didn't know. Creative has a full list of all their products and accessories listed here https://support.creative.com/kb/showarticle.aspx?sid=10846
Reply 52 of 56, by Martin85
So I have a system with a CT4620 installed along with the CT4660 breakout... All good and working. But somewhere I have a Live! Drive 2 lying in the dust... can I connect it to the soundcard and then connecting the CT4660 to the Live! Drive (CT4860A)?
Thanks
Reply 53 of 56, by y2k se
Martin85 wrote on 2026-05-03, 18:56:
Yes, this is the configuration I have.
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, Voodoo2, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
Reply 54 of 56, by Martin85
y2k se wrote on 2026-05-03, 20:25:
Great! Thank you for your feedback! In the meantime I happened to clean all the cards from the dust and check them for shorts. All looks good now, I even retrobrighted the plastics on one of them, because it was really too yellow 😀 But I am missing a volume knob. I think on the Live! Drive 2.
Reply 55 of 56, by B24Fox
Martin85 wrote on 2026-07-01, 08:06:
If you already have one knob, you can make a mold of it, out of silicone (be sure to grease the entire piece first, so it won't stick), and pour a new one out of epoxy.
You can even mix some paint into the epoxy to colormatch it.
Reply 56 of 56, by Martin85
Great tip, will try to do it, I think I have some of the stuff still at home... I just think that the knobs are made from some stiff rubber material, not really epoxy.
