First post, by shellshock404
Hello,
I am a novice to all of this so bare with me, but have enough basic knowledge to get by. I have a 486 PC all setup, all the hardware has been set in the BIOS with all the correct specs and settings, i don't get any other errors. So the next step I go to boot up the DOS install disk and I keep getting "Non system disk or disk error". I've tried about everything under the sun to troubleshoot this, used different floppy drives, cables, different boot disks, even an original DOS disk, keep getting the error. I have no idea what to do, I'm concerned the onboard motherboard FDD controller is broken. I have a ISA multi I/O card but I'm not sure how I get the BIOS to detect it or set it, I plugged it all in and I get nothing. Also to mention I have the boot order A: C: and the 3.5" is on the IDE A connector.
Let me know if you have any insight, I would appreciate it immensely.
Thanks.
Reply 1 of 8, by jakethompson1
That error is generated by the boot sector on a disk, never by the BIOS itself, so it's at least able to read the first sector. Make sure it's coming from the floppy and not the hard drive, e.g., by clearing out the hard drive settings in the BIOS. You'd need to disable the onboard floppy controller in order for the one on an I/O card to work. You're sure your floppy is bootable? You can format /s another floppy from another machine to check?
Reply 2 of 8, by Horun
shellshock404 wrote on 2022-08-29, 04:05:
Huh ? You have a floppy drive connected to an IDE connector ?
Ok. First thing first. What motherboard is it ? can you take a picture and attach it ?
The onboard floppy port should be just one connector, 34 pin. The onboard IDE usually has two 40 pin ports.
Next: The cable is important. Floppy drives are typically set to ID1, so if just one needs to be connected to the end of a floppy cable that has some odd twists in it.
Reply 3 of 8, by shellshock404
Sorry, it is a floppy cable and it's on the twist. I'm confident it is hooked up properly. The motherboard is some unbranded motherboard called an M919, i have the spec sheet attached. It also is a bootable disk I even tried using an original dos disk too, same thing.
Reply 7 of 8, by shellshock404
weedeewee wrote on 2022-08-30, 18:15:
try booting from floppy without the hard drive connected.
I did try this, the only device I have connected is the 3.5" 1.44mb
Reply 8 of 8, by weedeewee
1 Do you have another computer to try & boot the floppy disk you are using, absolutely verify that the disk(s) are working ?
2 to use an isa card multi io controller, you would need to disable (if possible), in the bios, the floppy controller, yet leave the settings for primary & secondary floppy drive. (if not possible... that's annoying)
- set the isa multi io card to only have the floppy controller enabled ( as primary), disable everything else, and connect the floppy cable to the correct connector on this card.
Do not ask Why !
