Reply 22620 of 29975, by appiah4
kingcake wrote on 2022-09-07, 13:29:
Made some dual CR2032 boards for my old motherboards with external battery header. I still feel better having the batteries off-board. (The diodes bring the voltage down to 4.8V. I feel more comfortable with a voltage around ~5V compared to 6V.)
Why 2 of these? Is this board for 4.5V boards?
Reply 22621 of 29975, by kingcake
appiah4 wrote on 2022-09-08, 08:57:
This is for boards that use discrete Motorola MC146818A RTCs. The datasheet says the battery should be 3 to 6 volts. There's usually a diode (or two) on the mobo that would bring a single CR2032 below 3V.
Reply 22622 of 29975, by mr-spain
Pretty much maxxed out what I can get out of this Gemlight 486 Board, Waiting on some more L2 chips should be here tomorrow. Working with a no-name VLB board next that has better bios options. The Gemlight I have to push changes to the registers while it's running to modify the cache and memory timing settings.
Reply 22623 of 29975, by Radical Vision
Did browse some of the gud NES 8 bit games. The main reason was to copy the emulator from that laptop, since i did configure it for best performance (sadly the VGA is ATi Rage Mobility 8MB, cant install Radeon with at least 32MB..), and to copy all that on the Voodoo V/ IBM system to have them.
The laptop did come with 128MB 1 stick originaly, and 10GB IBM TravelStar HDD, now is with WD Scorpio 80GB IDE and x2 128MB SDram. When i find cheap AF x2 256MB SDram (and ofc quality one such as Infineon, Micron or HyniX), will upgrade the machine. CPU wise is fine, but the GPU bothers me alot...
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 22624 of 29975, by Shponglefan
Radical Vision wrote on 2022-09-09, 20:03:
How is the input lag with NES emulation?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 22625 of 29975, by lolo799
Decided to open the Xerox MemoryWriter, some later models have a 8088 cpu, dual floppy drives and a monitor, there's a video on youtube if you're interested.
This is a simpler model, a 627 I think:
The attachment 20220909_205804.jpg is no longer available
The attachment 20220909_205912.jpg is no longer available
The boards from front to back:
The attachment 20220909_210235.jpg is no longer available
The attachment 20220909_210026.jpg is no longer available
The attachment 20220909_210100.jpg is no longer available
Reply 22626 of 29975, by PD2JK
Desoldered the battery off a PCChips M321 board and gave it a vinegar treatment. Also removed the glue before treatment.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 22627 of 29975, by Shponglefan
Continued working on my living room retro table setup.
Since it's in front of a hearth, it limits the floor space for putting a tower. I can only really fit one tower PC at the far end.
Also added the console gaming setup with the 1702 monitor. I'll probably build a stand for it so I can fit a pair of consoles underneath it with a video switcher.
I'm really liking the 1702 monitor for retro console gaming. Surprisingly good audio, even though it is mono (not a big deal for retro games though).
Reply 22628 of 29975, by Radical Vision
Shponglefan wrote on 2022-09-09, 20:21:
Well with the crappy ATi Rage Mobility 8MB it works great.. Ofc i did need to very fine tune the emulator in order to have good quality, resolution, and to work as if this was original Nintendo.. So i have no complains, it works exactly as i remember my fake console back 26 years ago, or even better...
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 22629 of 29975, by Private_Ops
Babasha wrote on 2022-09-07, 16:48:
Just start to tune my Asus-mania project! […]
Asus P3B-F mobo
Asus V3000ZX 3D Eplorer video
Asus Maestro-1 3D Explorer sound
Asus Intel 100mbit ethernet
Asus (!) DIMM module (in Asus original gold pcb color)
Intel PentiumII with free freq and multiplier…
Ugh.. I want one of those asus NICs... so hard to find. (or the 3com version, I'm not picky)
Reply 22630 of 29975, by Radical Vision
Asus P3B-F mobo
Nice mobo u got there, one of the very best Slot 1 440BX. But a word of advice, sell that crap ASUS, and find yourself something else (the other mobo i know that is on Slot 1 and supports native Tualatins is GIGAbyte BX2000+, not sure if MSI have one), since ASUS is so shit, they tend to die from nothing, and then they all do the same, not even spinning fans... I am trying to trade my P3B-F for BX2000+, since the GIGAbyte dying from no reason is far less possible, and the BX2000+ is superior board in terms of color and features...
Otherwise ur idea is good, whole system build from 1 brand only. But i like to look on that idea from another angle. For example some nice colored system like whole blue or whole black, and to have quality parts too, but is hard to mix and match the colour scheme and even more hard to be period corrected, but that is not 100% needed anyway...
Nexxen wrote on 2022-09-07, 17:35:
It's like a drink, ice or no ice is your choice :) Also for scsi, didn't know that but I guess everything, except tapes and othe […]
Radical Vision wrote on 2022-09-07, 09:53:
Sure there are Sata or CF ones. But i prefer the original look and feel, so just use on older system IDE. The flat IDE cable is just nice to watch...
It's like a drink, ice or no ice is your choice 😀
Also for scsi, didn't know that but I guess everything, except tapes and other funky stuff (bernouilli and sorts), are going to get a replacement with some solid state memory.
Today costs are down, cpu power is huge, prototyping is cheap.
Yay!!
Well u are right about that. The cost of newer stuff, that will do as good (or even better), as some older high end tech, but ALOT cheaper is true, for example there are ton of cards that are ALOT more powerful then any 3Dfx card out there (maybe only the Voodoo 1 and Voodoo II are exceptions, since they are very old and 3D accelerators, not GPUs), but yet everyone wants 3Dfx cards and even Voodoo V 5500, no mater that card suck hard vs even GEforce II GTS (hell even Kyro II is faster 🤣 ), but since the V5 is special brand it makes it very expensive. But i myself am all about the classic look, and the high end old school stuff, as they are cool, and they was the cutting edge stuff back when they were released. For example i like Quantum (and mostly FireBall, since i have mostly of them) HDD, since they are not existing anymore in the HDD space, no matter their noise is LOUD af, and after some time u will get stable headache, from that damn noise.. These Quantum HDD are prob. one of the brands that have the loudest noise out there... So yeah CF or SSD will be 100000 better, in noise, but wont be as cool and classic..
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 22631 of 29975, by Babasha
Radical Vision wrote on 2022-09-10, 11:26:
Asus P3B-F mobo
Tnx for your ideas!
Im already have a Tualatins ready “project” based on Abit BH20 OEM board all in black and gold colors.
My Asus “project” is based on period-correct Asus parts around PentiumII with downclocking possibilities.
PS. I have 6-7 alive P3B-F and 1-2 for spare)))
Need help? Begin with photo and model of your hardware 😉
Reply 22632 of 29975, by Radical Vision
Hmm P3B-F to be period corrected for Pentium II, interesting... Even when considering the models that should be ASUS P2B, for P2, and the P3B-F to be released at least year later, when Tualatin was made, not before that. But i dont know, the release dates. But just the model names suggest that, the P3B-F is not as period corrected, as the PB2 is.. Unless ASUS released P2B in the beggining of 1998, and the P3B-F in the end of 1998, or something like that..
That is good u have much of these working, mine works too, but some other ASUS boards i had did die..
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 22633 of 29975, by Babasha
Radical Vision wrote on 2022-09-10, 12:15:
My P2B needs some minor repair. Will downgrade motherboard later.
Reply 22634 of 29975, by Windows9566
what asus boards died on you?
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
Reply 22635 of 29975, by rkurbatov
My first attempt to retrobright.
Also, got an old 5.25" for less than $1 - cleaned and greased it - seems working. It's front panel now will stay for a night in my bathroom 😀
Tomorrow will work with a case (and floppy) - try to remove rust and paint it.
486: ECS UM486 VLB, 256kb cache, i486 DX2/66, 8MB RAM, Trident TGUI9440AGi VLB 1MB, Pro Audio Spectrum 16, FDD 3.5, ZIP 100 ATA
PII: Asus P2B, Pentium II 400MHz, 512MB RAM, Trident 9750 AGP 4MB, Voodoo2 SLI, MonsterSound MX300
Reply 22636 of 29975, by Veeb0rg
Ordered everything I should need to build one of the Pico to AT adapters that's being developed on this forum.
Reply 22637 of 29975, by bjwil1991
Got the PCS desktop working by swapping the board and GPU (both the Trident VGA/EGA and the BioStar board aren't functional and my plan is to fix the BioStar board and get it installed). The Koalk 20MB drive works and it'll get archived once I receive other components and format a hard drive and the turbo display has 1 speed selection that doesn't show the full number and only has 2 of the 10 segments lit up, yet the others work fine: 33MHz is the one that has issues, which means a reflow of every IC needs to be done and if that fixes it, I'll call it a day. That and I need to label the connectors so I know which one is which for the reset button and keyboard lock since they share the same wire colors blue and indigo.
Reply 22638 of 29975, by LezRed
Today I've been rescuing files from a 2003 era Medion PC. A friend of my fathers sadly passed away earlier in the year and he'd worked as a publisher and had published some of my fathers own work. I was asked if I could get some files off the 'tower' and was told it was 'modern'. Knowing the chap had been in his 70's when he passed I actually expected this to mean Windows 7 or maybe 8 and a SATA HDD or maybe even an SSD. Nope, a Pentium 4 2.66GHz with Geforce MX 440 and 2 x IDE HDD's and complete with a 56K modem and fancy front panel complete with CF, USB, audio jacks and SVHS and composite outputs.
I'm now pulling all the old images, and quark express files off via USB for archiving. No one wants the PC itself so I've offered to give it a home to save it from someone carelessly throwing it in landfill - my offer was accepted 😀
Reply 22639 of 29975, by kingcake
Today I'm working on an 8088 board with some burned up Tantalums. (Took these with my Microscope)
The attachment FcalENxWQAE566T.jpg is no longer available
The attachment FcakxPZXgAA7SpI.jpg is no longer available
