First post, by 8bitbubsy
I think my 486DX4-100 may be slightly unstable because of my BIOS tweaks, but the crash happens so rarely that I don't know for sure if it's the RAM/cache timings or a regular software crash. Are there any good tools out there that puts a big load on the CPU, caches and RAM at the same time, for testing the stability? I run Windows 95 (and DOS).
386:
- CPU: 386DX-40 + 40MHz FPU + 128kB L1 cache
- RAM: 8MB (0 waitstates @ 40MHz)
- VGA: Diamond SpeedSTAR VGA (ET4000AX 1MB ISA)
- Audio: Sound Blaster Pro 2.0 + GUS 1MB
- ISA PS/2 mouse card
- MR BIOS
Reply 1 of 4, by Sphere478
Phil’s computer lab has a benchmark suite.
Could try that
For cache and ram memtest86+ is a good one.
Can make boot disks for it
Sphere's PCB projects.
Reply 2 of 4, by rasz_pl
you could run winquake demo loop. Lots of ram used, protected mode, MMU used, multitasked, seems to cover all bases.
Reply 3 of 4, by Horun
Sphere478 wrote on 2022-09-11, 22:54:
Phil’s computer lab has a benchmark suite. […]
Could try that
+1 as the first thing to run ! Being a test that runs not off the HD or with any OS drivers loaded it can show more deeply if a Ram, cache, cpu hardware issue is at fault.
If it passes then try other other tests based on when you notice the most crashes. Like if under DOS then DOS tests first, if under just WIn95 then well it could be many driver things....
Reply 4 of 4, by 8bitbubsy
Been running WinQuake (v1.09) for over half an hour at 640x480 fullscreen, without issues. Maybe the issues I've had are not related to unstable hardware.
I did play Curse of Monkey Island yesterday (just as a test to see if it would run on a DX4-100), and it froze after like 15 minutes of playing, but it's possible that it was related to buffering issues because it did go out of sync every now and then...
386:
- MR BIOS
