First post, by crash.
- Member
I'm trying to use a serial joystick device whose driver will not load since it detects there is already a mouse driver in memory.
The device is a Logitech Wingman Warrior joystick, and it is connected to the computer via a USB to serial adapter on COM4. I have configured dosbox to use this serial port.
The message I receive is:
Another mouse driver is present in memory, this mouse driver cannot be loaded. Please remove the existing mouse driver then load this mouse driver.
I tried inserting the following in the dos section of the dosbox config:
int33=false
Is there any option to prevent dosbox from loading it's own mouse driver?
Thanks
