First post, by crash.
I'm trying to use a serial joystick device whose driver will not load since it detects there is already a mouse driver in memory.
The device is a Logitech Wingman Warrior joystick, and it is connected to the computer via a USB to serial adapter on COM4. I have configured dosbox to use this serial port.
The message I receive is:
Another mouse driver is present in memory, this mouse driver cannot be loaded. Please remove the existing mouse driver then load this mouse driver.
I tried inserting the following in the dos section of the dosbox config:
int33=false
Is there any option to prevent dosbox from loading it's own mouse driver?
Thanks
Reply 2 of 5, by crash.
Oh thanks, I will try that. I had run across a different method using a program called MOUSEOFF that I found here, but I'll try the correct method. Thanks!
Re: Mouse problem
download/file.php?id=5488
Cheers
Reply 3 of 5, by crash.
I tried, but my config file for the Windows version does not have a [keyboard] section. I tried adding one with this information but it did not function.
Thanks
Reply 4 of 5, by _Rob
Start dosbox-x and run the command
config -wcd -all
A new config file will be created.
Reply 5 of 5, by crash.
I have not been using DOSBox -X, but was using DOSBox. I installed and configured DOSBox-X, then disabled the mouse (auxdevice in the the keyboard section) using the included DOSBox-X configuration tool.
Thanks
