First post, by Agt41510
Hopefully this can help those looking to record music.
Does the ensoniq soundscape s-2000 work on a windows 98se? Picture attached.
I was able to get a opus working effortlessly using the same installwizard. Does the sndscape.iso have all of the files for the s-2000, though?
I still have the yellow exclamation marks on the s-2000. Desperate for answers so I'm just throwing out all I've done.. It picks up the s2000 in dos mode.. but won't show up on audacity. What do i need to do? It tries to make it seem like it's working but it still has the yellow (!)
Reply 1 of 9, by pyrogx
S-2000 is not a PnP card. You need to configure it manually.
Did you check why there is a yellow exclamation mark in the device manager. Normally Windows tells you why...
Reply 2 of 9, by Agt41510
pyrogx wrote on 2022-09-13, 11:09:
"this device is either not present or not working properly "code 10""
By manually do you mean in DOS? Whenever i get to DOS it looks like this (attached) automatically then goes to c:\windows>
Thanks!!
Reply 3 of 9, by dionb
Agt41510 wrote on 2022-09-15, 04:23:
"this device is either not present or not working properly "code 10"" […]
Thanks!!
No, you need to do it in Windows. With non-PnP cards like this you need to manually tell Windows (in Device Manager, at the Resources tab for the card) which resources it uses, so which base address, IRQ and DMA.
That error is telling you that there's no S-2000 in there with the resources currently configured, so you need to correct them to whatever values you chose when installing in DOS.
Reply 4 of 9, by Krzysztof Zakrzewski
I’m looking for drivers for the Ensonic SoundScape S-2000 that would work on Windows 98. In DOS there are no problems—the card works correctly.
In Windows 98, MIDI and the MIDI mapper work, but wave audio does not, and the device is not available. During installation, I correctly set the addresses
Reply 5 of 9, by twiz11
Krzysztof Zakrzewski wrote on Yesterday, 22:08:
have you tried the drivers for 95 or 3.1 as a backup?
Reply 6 of 9, by Krzysztof Zakrzewski
twiz11 wrote on Yesterday, 22:54:
I tried these drivers: https://archive.org/details/s2k0105a_zip
-thanks to them, MIDI works.
I also tried these ones: https://vogonsdrivers.com/getfile.php?fileid= … 183&menustate=0
The device seems to be detected, but nothing works.
Reply 7 of 9, by twiz11
Krzysztof Zakrzewski wrote on Yesterday, 23:02:
I tried these drivers: https://archive.org/details/s2k0105a_zip -thanks to them, MIDI works. I also tried these ones: https://vo […]
hmm i got an idea why not try a standard creative soundblaster 2.0 driver of the day. just choose one that came out the same time frame, maybe it might work. I know ensonic was absorbed into creative there may have been similarites
Reply 8 of 9, by mkarcher
twiz11 wrote on Yesterday, 23:18:
Using an SB 2.0 driver might in fact work if the S-2000 is initialized in DOS with the usual drivers, but result in a clearly sub-par experience for digital sound, atrocious FM synthesis (the card doesn't have any OPL, this is unfixable), but usable MIDI, if an MPU-401 driver is installed at the same time. To get good digital sound from the S-2000, you need a driver that uses the AD1848 codec instead of the soundblaster emulation provided by the Ensoniq Soundscape architecture.
If you just use the S-2000 for MIDI and add a cheap SB Pro/WSS board for digital sound and FM, and route line out of the cheap SB Pro/WSS board into the S-2000 you get a configuration that worked quite well (nice wavetable Music, good SB Pro & WSS compatibility, depending on the SB Pro clone fair to perfect OPL3 FM) for a friend of mine in the 90s.
Reply 9 of 9, by Krzysztof Zakrzewski
Generally, my goal is to use the S-2000 for MIDI, especially with an Intelligent MPU and the Roland MT-32.
However, I was hoping that Windows 98 would also provide digital audio.
