Reply 320 of 1356, by Sphere478
Yeah, I know. It’s a mess still. Not even beta yet man 😀 it’ll get there. Thanks for the feedback though. It is important.
Not much point in pointing out flaws just yet as there are so many left to fix. Gimme a little bit to attack the trace and plane routing and then get back to me 😀 ground islands and right angle traces are definitely on my radar. 😀 if I can’t land both ends of that plane somehow by playing with the traces I’ll probably add a via to the ends to kill the antenna effect as you call it.
I saw that effect first hand on microwaves. It was wild how a bad spot weld in a waveguide connected elsewhere would still get a induced voltage difference and spark right in the middle of all that metal.
Sphere's PCB projects.
Reply 321 of 1356, by Sphere478
I've done some pondering and am going to start over on the trace routing entirely. It has been in the back of my mind that clocking the socket differently may give better routing possibilities. Also having pin 1 on two different corners is really bugging me
I left the large socket as is and am going to try a slightly modified method of trace routing that focuses on minimizing vias. and not being so stringent on the direction traces are going on each layer.
and as a bonus surprise, bendy traces.
Reply 322 of 1356, by maxtherabbit
sexy hand etched 70s vibe
Reply 323 of 1356, by Sphere478
Thx 😀
Calamitylime found a plug in somewhere that tear dropps the ends also, I could try looking into that.
I’m having trouble getting some routed. I think this has a lot to do with trying to use larger traces.
I’ve started using the top and bottom layers also to try and keep the larger traces 🙁
Reply 324 of 1356, by Sphere478
This is quite the puzzle.
Trying a bunch of different ideas. One of these ideas is bound to be better than the rest. 😀
Thoughts H3nrik V!? Both approaches aren’t finished but what do you think has better attributes? This way or previous way?
I can probably spread out those signals in the middle a bit, maybe even stagger them layer to layer. 🤔
Reply 325 of 1356, by H3nrik V!
Well, I'm not a fan of those soft curves on the tracks - probably mostly for an ocd point of view 🤣 otoh I've never been a fan of the "x-layer, y-layer" philosophy, all though that is a proven widely used way of routing. I probably more "feel" how I want it to be, but preferably always trying to get room between tracks for connected ground in both ends ... But then again, my pcbs have been laid out to meet all sorts of emc/emi requirements, which is not a hard requirement on hobby pcbs, all though it can prevent all sorts of other problems ...
Damnit, I'm avoiding a direct answer here .. Mostly probably because both ways will work fine and at the end of the day being a question of ease of routing and aesthetics. Only thing is - never ever ignore having a full ground as well as a supply plane, preferably with the same z-spacing to routing layers.
Reply 326 of 1356, by Sphere478
Got another idea on the drawing board.
Since with this clocking of the socket there is a lot of tracks going lower left to upper right I am trying to run a bunch of evenly spaced tracks with ground planes stitched between. And will use the lower layer (blue) for lower right to upper left.
Reply 327 of 1356, by H3nrik V!
I don't have the full overview, but would there be a benefit from rotating one of the sockets in terms of routing it all?
Reply 328 of 1356, by Sphere478
H3nrik V! wrote on 2022-09-22, 03:52:
Some orientations are better than others but not by much. Its almost like they flipped the die inside the package and made this mess.
I’m trying to make this orientation work currently because it puts pin 1 in the same corner on both sockets. I figured that would be best.
Reply 329 of 1356, by feipoa
Yeah, having pin 1 in the same corner for both PGA132 and PGA168 would reduce the probability of the unit being inserted incorrectly. However, if there's a much more ideal rotation for routing traces, I think that would take priority.
Reply 331 of 1356, by Sphere478
May have had that clever idea I was looking for.
The blue traces are only on the blue outer layer.
But The other rows going the other way utilize all four inner layers but there are only two traces stacked in each row with a ground plane between and they alternate. so everything passes through the middle in a nice cozy little ground plane. With lots of separation.
Not sure if dropping those vias in the middle of those pads is gonna make a DRC or jlc throw a fit but man does it make a nice layout in the center🤔… it should work fine physically though as long as they can make it.
Now to see if I can connect the pads to this thing I built in the center.
Thoughts?
The attachment image.jpg is no longer available
Edit:
Playing with the blue layer a bit before I give it a rest for the night.
edit 2:
progress backup done for tonight, more soon.
Reply 332 of 1356, by feipoa
Looks like progress. I personally like the smooth curves on the traces. What was the reason modern PCB's use 45 degree sharp turns rather than smooth curves?
I have received Blavius' PCB and assembled it with spare parts. I'll have to get a testbed setup in short order.
The attachment SXL2_interposer_side-by-side_PCB.JPG is no longer available
Reply 333 of 1356, by rasz_pl
feipoa wrote on 2022-09-24, 10:03:
Computational complexity. Curved traces are the best, not because electron holes/charges have trouble turning in 90 degree corners 😀 but because of under-etching (especially when working at the extreme end of fab capabilities), mechanical rigidity, and electromagnetic properties in case of really fast signals (thing PCIE 5 or DDR3, not 40MHz cpu bus). To render curved traces you need bezier curves and/or splines, pretty much like rendering proportional fonts, except every trace is like a separate letter so cant pre render whole alphabet and just copy. It was extremely slow in 80/90 so we stuck to fast easy approximation with obtuse angle corners. Nowadays speed is of no issue, so its just inertia of old designers and their aesthetic tastes (curved looks like grandpa taped it out by hand, I have OCD/mild autism and everything must look like symmetric robot vomit etc).
Reply 334 of 1356, by Sphere478
Robot vomit lmfao
I think the 45*/90* thing probably came about because of cad. As before they used to be hand drawn.
Reply 335 of 1356, by Sphere478
Wasn’t able to use alternating tracks. (Not enough paths.
Thoughts on 8 layer?
Reply 336 of 1356, by feipoa
I've no experience ordering PCBs of more than 2-layer, so I have no idea how much more cost it will entail per PCB. The thickness of the PCB itself shouldn't matter, so no difference to have it a bit fatter if necessary.
Reply 337 of 1356, by Sphere478
feipoa wrote on 2022-09-29, 06:20:
Well, connections were landed on previous version alpha 1 though It was a total mess. Also getting the center caps to their power planes was a bit tricky. But it did look like I was going to be able to clean it up a lot better than it was. But perhaps not as good as I wanted.
The pin one was shifted since then which I think is a good call.
This attempt is trying to do two things, avoid so many vias, use bendy traces, and improve routing for better signal.
So far it isn’t going as well as hoped.
I’m trying 8 layer. See how that goes.
I made a 8 layer and threw a few traces down and generated a gerber. Jlcpcb has it at 86$ for 5 pcbs.
Vs
7$ for uploading a 6 layer.
But it says it is 4 layer on the 6 layer and says 6 layer on the 8 layer.
Idk if it is getting confused or what? But jlc only has options for 6 layer.
I’ll probably go back to 6 layer and keep trying to make that work.
Reply 338 of 1356, by Sphere478
Gave up on the bendy traces. Went back to a x,y,xy,yx routing scheme but with focus on avoiding vias when possible.
Saved last draft of bendy trace attempt:
The attachment CPUInterposer386-486 alpha 3.zip is no longer available
Reply 339 of 1356, by Sphere478
Next iteration will probably be a beta.
Improvements since previous 45 degree version:
-DRCs of consequence solved,
-Traces better aligned,
-Larger traces,
-Pin 1 aligned
