First post, by GoldenPentium
Hello everybody,
I bought Am5x86-P75 133 ADW to my collection and it seems that CPU came already broken. Computer doesn't start. My jumpers' setup below.
The attachment ls-486e-5x86.png is no longer available
After the some experiments I figured out that CPU has only 167 pins - pin D28 is missing (damnit). What is the purpose of this pin? Could it be the reason of malfunctioning? Is that possible to solder a new pin to fix it?
Reply 1 of 4, by majestyk
D28 is one of the 32 I/O (Data) pins, so it´s necessary for operation.
Reply 2 of 4, by Disruptor
GoldenPentium wrote on 2022-09-10, 01:28:
Yes. Perhaps you try to solder a leg of a LED on the CPU.
But check before if the leg fits into the CPU socket.
Reply 3 of 4, by GoldenPentium
So, it was definitely broken CPU. Got refund and then bought a new one - ADZ. Now everything works fine.
Thank you all!
P.S. anyways, will try to fix ADW though.
Reply 4 of 4, by rasz_pl
Instead of soldering new leg you can experiment with fitting cut to length resistor/led leg into the socket, then installing CPU over it in a way it constntly pushes into that leg
