First post, by Shponglefan
I'm looking for ideas on storing keyboards. Currently I have just been leaning them against each other on a shelf. But it's been a pain any time I need to pull out a keyboard, cords keep tangled, etc.
I'm looking for ideas for more elegant solutions.
486 DX-33 with 5 sound cards
Tandy 1000 TL restoration
Ultimate Windows XP build
Reply 1 of 10, by waterbeesje
The most elegant solution would be to create some sort of case where there's one board per shelf
I came across this one:
https://i.redd.it/h1wn027yvbdy.jpg
I'd make it out of varnished wood and with closed sides.
Note: I've stacked my spare keyboards six high on top of a shelf, in a few rows. Nothing elegant about that, but it works 😀
Stuck at 10MHz...
Reply 5 of 10, by Baoran
I have only piled them on top of each other so far of a shelf. This makes me wonder if I am damaging them somehow by just doing those. I suppose there is most weight on the bottom one when there might be 4 others on top of it but so far I have not had any problems with any of them when I take one out and use it.
Reply 6 of 10, by Shponglefan
Baoran wrote on 2022-09-27, 22:07:
This was my concern too. That plus, I keep getting their cords tangled.
Reply 7 of 10, by Horun
As long as you do not do this think you are OK: https://www.alamy.com/stock-photo-stack-of-ke … p-57159640.html
Hate posting a reply and then have to edit it because it made no sense 😁 First computer was an IBM 3270 workstation with CGA monitor.
Reply 8 of 10, by BitWrangler
Umm, I accidentally a couple of small piles like that.. mostly the modern ones though....
If I'm deliberately storing them, they get the cord hanked and tied with a baggie over it, and stood vertical on their top edge in a fruit box with sheets of corrugated card between them.
Reply 9 of 10, by debs3759
I was going through a cupboard a few days ago. Got 9 keyboards on end in a box, that has been stored for so long that the box has rotted (it's an outside cupboard that was under a leaky roof before I noticed and had it repaired. I sense a certain amount of restoration is going to be in order, but at least I know I have a nice supply of AT and PS/2 keyboards, when I add them to the shelf I have several stored on inside. It's a low shelf, with keyboards angled on top of each other, so no weight issues and minimal space needed.
Reply 10 of 10, by original_meusli
I use these for my keyboards, pedals and mice when not in use.
https://www.ikea.com/gb/en/p/flisat-wall-storage-00290778/
I can keep my CH rudder pedals and my Thrustmaster TPA3 Pedals in one shelf and I also have three retro PCs that I keep the mouse and keyboards in stored behind them on the wall. Really useful shelves for this.
