First post, by tsalat
Hi everyone,
I got myself the XGECU TL866II Pro to flash one or two bios images for my old 386 board (https://theretroweb.com/motherboards/s/gemlight-gmb-386umc). The problem is, I can read the EPROM but while trying to flash, I will always get an error. I am sure I am doing something wrong and thus I hope someone can help me. I do have some original AMI bios chips with apparently different images and I believe that those chips are: L27C512. I have therefore selected this IC in the XGECU and it listed several manufactures, I have chosen some (some returned straight error during read). After reading I have loaded the bin file from the link to the mobo and started to flash, but I always get something like:
ERROR!  Address:0x008150   Buffer Data:0x44   Verify:0x00
now I am lost. Dont know how to proceed. Any advice?
thank you, Tomas
Reply 1 of 9, by Repo Man11
I have no personal experience with programming UV erasable chips, but it seems they have to be erased prior to being flashed?
https://www.youtube.com/watch?v=EghQ7YXIhm8
Reply 2 of 9, by tsalat
Repo Man11 wrote on 2022-10-04, 16:41:
Yes, you are right. I have the ones without the window, okey, ebay 😀
thank you for your reply, at least I know now, from reading the EPROMs I have that none of them matches the BIOS I need.
edit: nope, there is the window, under the sticker 😁
thx, tomas
Reply 3 of 9, by tsalat
The Winbond W27C512 seems to be like a good option to replace the old EPROMs with EEPROMs.
Will go with this solution.
thx, tomas
Reply 4 of 9, by rasz_pl
you dont need special UV lamps to erase 27C chips, nail polish hardening led one stolen from wifey will do 😀 or just put it in the sun for a couple days (obviously not in the open weather)
Reply 5 of 9, by weedeewee
rasz_pl wrote on 2022-10-25, 06:11:
Those water purification lamps, (UVC lamps) also work.
as for the couple of days... seems highly dependent on size, technology and sunshine ( https://goughlui.com/2016/09/11/experiment-ti … by-uv-lamp-sun/ )
6 days for an 8KiloByte chip and over 3 months for a 1MegaByte chip.
Do not ask Why !
Reply 7 of 9, by tsalat
My wife doesnt have one but sounds like a good Christmas present 😁
I have one sterilization lamp that I have bought during the COVID - just from curiosity... will try that one if there will be some time.
thx for the tips!
br, tomas
Reply 8 of 9, by LeFlash
Be careful, don't look into the uv light and don't expose your skin for a longer time. Best way is putting eproms and shield it with some books
Reply 9 of 9, by tsalat
LeFlash wrote on 2022-11-18, 08:11:
yeah, i know, thx anyway for the safety tips 😀
I kept the UV lamp in the package, never tried it.
