First post, by zwrr
Hi all, I built a K6-2 computer to run old DOS games, then I got a SCSI card, model number SYMLOGIC 83C875J, from an old Compaq server, but I found this SCSI card It seems that there is no BIOS chip installed, after my K6-2 host is booted, the motherboard assigns an interrupt to the SCSI card, but does not show any SCSI card initialization scan device information, I doubt whether the SCSI card BIOS is stored on that Compaq server in the motherboard BIOS.
Is there any way to use this SCSI card on a normal motherboard?
PS: I am not an English speaker, the above text is translated by Google, please forgive me if there are grammatical errors.
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
Reply 1 of 3, by weedeewee
That card doesn't seem to have an (eep)rom, so you shouldn't expect any on startup scsi bios initialization.
If it does so on a compaq, then the scsi bios was integrated with the main computer bios.
Using it in dos/windows should work if you install the drivers for a symbios logic 83c875 scsi controller
Do not ask Why !
Reply 2 of 3, by Babasha
zwrr wrote on 2022-10-07, 00:09:
What you need from this card? Be bootable or just connect HDD(s) and see it in DOS/Windows or other system?
Need help? Begin with photo and model of your hardware 😉
Reply 3 of 3, by led178
Board without bios.
NCR SDMS 3.xx can be built into the BIOS of the motherboard, but it does not know the 53c875j chip, version 4 is needed. But it is larger in size and I don’t know how to embed it 🙁
Regular dos drivers are not suitable, you need FWS2ASPI.SYS
(https://support.hpe.com/connect/s/softwaredet … MTX-UNITY-I7597)
Links:
https://groups.google.com/g/comp.periphs.scsi … cPbZFRo0J?pli=1
https://www.phantom.sannata.org/viewtopic.php … =657953#p657953
