Reply 300 of 631, by Joseph_Joestar
- l33t++
BEEN_Nath_58 wrote on 2022-09-05, 18:38:Can you try this game with a Table Fog compatible chip and see how the game reacts to distance (and and relevant screenshots for proper visible fog which I didn't find in vertex one).
Not sure if this was addressed at me or others in general, but I don't own that game and I'm not familiar with it. That said, if you (or anyone else) wants to test table fog and paletted texture support in certain games, all that's needed are two cheap and readily available graphics cards.
A GeForce 2 MX400 fully supports both table fog and paletted textures, and can use early Nvidia drivers like 7.76 which makes it very compatible with older games. The other card would be an ATi Radeon 9250 which doesn't support paletted textures nor table fog. Simply run the game that you want to test on both cards, compare the results, and document your findings with screenshots.
I can add any newly tested games to the Vogons wiki, provided that the tests are conducted on real hardware (no emulation or wrappers) and that proper comparison screenshots are presented.
