First post, by Neelix
I would to extract a MS Cabinet file at system startup from the floppy to a virtual drive using EXTRACT.EXE.
I found Winlight, a DOS 7.1 and Windows 3.11 based system, designed to
help fixing a broken DOS system on old machines.
I decided to improve it, adding some commands.
Then, I need to compress the system into a Cabinet file, like it was on the original disk.
I found cabsdk, containing CABARC.EXE that runs under Windows 98 and IEXPRESS.EXE, running under Windows 2000, but,
my CAB file is not extracting, from the floppy.
I added the command ECHO ON to autoexec.bat and ran the system Step by Step. No error occurs, but the only file extracted is
DOSIDLE.EXE. It's size is 0 bytes.
But, running a MS-DOS 6.22 system on a Virtualbox VM, the Cabinet is extracted without problem.
Could some one help me, please ?
Reply 2 of 9, by Neelix
I fixed my problem using version 1.00.0601.2 that comes with IEAK 5 with default LZX compression.
But, increasing the compression level, it doesn't work anymore.
It could be that the EXTRACT.EXE command has not enough memory.
So, I manage to use HIMEM AND EMM386, but, I must compress some drivers files to increase my floppy disk space.
But the CONFIG.SYS is loading the drivers before AUTOEXEC loads the EXTRACT command.
Is there a way to extract some files before loading the drivers in CONFIG.SYS ?
Reply 3 of 9, by Neelix
Hi Guys,
This morning, working, I found out that the error out from the EXTRACT command was redirected to nul. Suppressing the '>nul ' from
the command line, I got this error:
ERROR: Out of memory while processing cabinet file Winlight.cab
However, the cabinet is well extracted when booting and extracting it from the hard drive. Why that ?
I wonder if someone could explain that mystery.
Reply 4 of 9, by Azarien
Neelix wrote on 2022-10-12, 10:13:
You mean, even after compressing everything you don't need in your config.sys, you still cannot fit on a floppy?
In such case consider switching to a bootable CD. It emulates a floppy and as such is still limited in size, but that floppy image may load a CD-ROM driver and MSCDEX, so you get access to normal CD filesystem which should be big enough 😀
Reply 8 of 9, by DosFreak
You can try 7-zip
https://www.ibiblio.org/pub/micro/pc-stuff/fr … /7zip/7zdecode/
https://www.ibiblio.org/pub/micro/pc-stuff/fr … ile/7zip/15.09/
Make your games work offline
