An EPIC Single Socket-8 Build
Reply 40 of 156, by pentiumspeed
Irinikus wrote on 2022-10-15, 17:50:
Do any of you know if this type of RAM will work in this machine? (It would allow me to load the machine up with 1.5GB of memory […]
Do any of you know if this type of RAM will work in this machine? (It would allow me to load the machine up with 1.5GB of memory!)
They are 256MB EDO ECC server modules, and the Pentium Pro motherboard does support ECC.
Not compatible. Look at the contact fingers, they does not have vias that connects two fingers on front and back vs standard 72 pin simms. Will burn out if you try.
Cheers,
Great Northern aka Canada.
Reply 41 of 156, by luckybob
BitWrangler wrote on 2022-10-15, 18:07:
Someone perform the ritual of luckybob summoning, I'm sure he will have notes.
I've seen these modules. I've always assumed they are not compatible. 128mb is the maximum without going into the realm of proprietary.
Reply 42 of 156, by Irinikus
pentiumspeed wrote on 2022-10-15, 23:26:
Cheers,
It was indeed the lack of the via at the top of each finger that made me question their compatibility and do more searching.
There are allot of sellers marketing them as SIMM’s, which is potentially dangerous!
768MB it will have to be then!
YouTube
Reply 43 of 156, by Irinikus
Thanks for all of your inputs, I really appreciate it!
YouTube
Reply 44 of 156, by Irinikus
Another question:
Is there a significant difference in performance between 60ns and 40ns EDO?
The problem with this is that I've only been able to find 64MB SIMM's @40ns, and this would limit the machine to 384MB, which would cause the machine to make excessive use of its page file, rendering the speed improvement null and void!
YouTube
Reply 45 of 156, by luckybob
Measurable? Yes.
Practical? No.
Reply 48 of 156, by Irinikus
This is probably the way I'm going to go:
YouTube
Reply 50 of 156, by Irinikus
Sphere478 wrote on 2022-10-16, 06:52:
https://www.ebay.com/itm/303649179445
These are the ones I use for 512mb on my tyan s1564d
Thanks for the suggestion, as that memory comes at a very good price. (The ECC memory is 3.3 times the price!)
Call me crazy though, as I do want to install ECC RAM, as it's one of few the tricks that the Pentium Pro (Socket-8) has up its sleeve! I know that it won't offer any performance benefit, but it is a rather cool feature, and one of the features which sets the Pentium Pro apart.
I'm crazy, I know!!!
YouTube
Reply 51 of 156, by Irinikus
Correction to last!
@Sphere478, I see that your dual Pentium Board also supports ECC memory, so it not purely a Pentium Pro thing!
Very nice board, by the way!!! 😀
Thinking about it, EDO offers better performance than FPM, so I'll definitely consider the RAM that you recommended!
YouTube
Reply 53 of 156, by maxtherabbit
Does "ECC" in the context of 72-pin SIMMs really mean anything other than parity (36 bit)? I.e. you can just use any old parity SIMMs for ECC mode, right?
Reply 54 of 156, by pentiumspeed
ECC 72pin SIMMs are 10 ICs per side, providing 40 bits. HX chipset supports this as long as motherboard supports 40 bits ECC SIMMs.
36 bits SIMMs are parity always and will crashes the PC if parity error is caught. 32 bits is non-parity which you have now, and will not get caught if there's error which will corrupt the storage and issues, including windows breaking itself.
Best of all is ECC, which fixes bit errors on the run.
Cheers,
Reply 55 of 156, by PC-Engineer
No, the chipset can use the one parity bit for error correction (ECC). And this one additional bit is also sufficient for this. The BIOS must have implemented a sufficient support for it. With the Intel Socket 7 chipsets only the 430HX could do it. On the Socket 8 / Slot1 chipsets, most of them could, except for the budget versions (440EX and 440ZX). With my ASUS P6NP5 (and T2P4) i can use ECC with 36Bit EDO modules.
Epox 7KXA Slot A / Athlon 950MHz / Voodoo 5 5500 / PowerVR / 512 MB / AWE32 / SCSI - Windows 98SE
Reply 56 of 156, by TrashPanda
Just realised OPs socket 8 is only 72 pin Simms, mine is 168 Pin EDO ECC Simms which I initially thought were SDR PC66 modules as the EDO ECC modules look identical except for the first notch being slightly closer to the outer edge.
Perhaps this is due to mine being a 440FX.
Wonder if my board support buffered EDO ECC ..only one way to find out I guess.
Reply 57 of 156, by Irinikus
This board is based on the Intel 82440FX three chips PCI set and it has ECC support.
YouTube
Reply 58 of 156, by TrashPanda
Irinikus wrote on 2022-10-16, 21:02:
This board is based on the Intel 82440FX three chips PCI set and it has ECC support. […]
Mines a NEC job with integrated SCSI, Video and a few other server related things, seems 440FX came with a wide range of memory support.
The attachment NEC Express 5800-110A Pro.jpg is no longer available
The attachment Im not SDR PC66.jpg is no longer available
You can see why I thought this was PC66 SDR
Reply 59 of 156, by Sphere478
TrashPanda wrote on 2022-10-16, 20:52:
I am pretty sure that electrically you can put 168 pin EDO slots on anything that has 64 bit bus paired Simms
with some trickery probably 30 pin simm motherboards if you wired the slot as stacked so it was only as wide as the bus?
Sphere's PCB projects.
