First post, by sofakng
What's the smallest motherboard form factor that has ISA slots and can support a Pentium (MMX) CPU?
The PC/104 standard is fantastic but doesn't have ISA unless you use adapters, etc.
I'm wondering what is the smallest PC I can build that can use a real soundcard (ie. Adlib, etc) and has a full set of I/O ports (serial, parallel, etc).
