First post, by Scythifuge
- Oldbie
Greetings,
I am using a NIC based on the RT8139D chip since there are drivers for DOS and WFW3.11 which I will then be able to use to surf the information super-highway, send emails, download files from FTPs, and play some MP games. I used to be a lot better at tweaking my start up files, but these days I am using DEVLOAD /H to load some stuff into upper memory in order to be my precious 600-624k. However, once windows /net kicks in, it loads some other stuff which eats the ram. Also, I am not sure why, but MSCDEX is using 32k whereas during my tweaking of this same machine over the past few days, it was 16k at some point. Maybe DOS 7.1 and Windows 3.11 have different versions? I would definitely like it to use only 16k if possible.
Does anyone have any ideas about how to load the net stuff into upper memory, and why MSCDEX is jumping between 16k and 32k? Ultimately, I can create a multi-config.sys (which I may do for various reasons, such as reading about some AWE32 drivers which aren't need for games, apparently,) but I would like to maximize my startup files before doing so. Thank you!
