AdLib GOLD clone is now a reality
Reply 60 of 228, by Thermalwrong
Why not use solder paste with a stencil? That should cut down on most of the SMD soldering element. If you want to scale up production further, something like the Lumen PnP can do the component placement - I've been following that project for ages but have nothing I'm making that would benefit 😀
I use the TS100 about the same way but I'm not good at soldering SMD stuff by hand, always too much or too little solder.
Reply 61 of 228, by keropi
I have created the GOLDLIB page here and entered ordering info: http://pcmidi.eu/goldlib.html
Anyone interested should check it out, hope you don't get bored by the wall of text 😀
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 62 of 228, by Shponglefan
keropi wrote on 2022-10-19, 15:09:
Sweet! Definitely psyched for this card, so looking forward to it! 😁
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 63 of 228, by Lennart
Very nice! 😀 I asked this before, but I don't think I got a reply. Are there any plans to sell the surround module separately? I've got an original Adlib Gold that could really use one.
Reply 64 of 228, by Boohyaka
Super sweet! Congratz guys! <3
Reply 65 of 228, by keropi
Lennart wrote on 2022-10-19, 15:45:
I am sure we can arrange that 😀
also everyone, thanks for the support! 😀
Reply 66 of 228, by Lennart
keropi wrote on 2022-10-19, 18:09:
Awesome! 😀 I just filled out the form and added a note that I'm interested in the surround module only.
Reply 67 of 228, by keropi
I still have to check though if I have enough yamaha surround chips - it was a PITA to get these and be actual real working ones...
Reply 68 of 228, by moturimi1
keropi wrote on 2022-10-19, 20:18:
Best retro sound project ever!
..do you mean that there it a problem with fake chips from China?
Reply 69 of 228, by jskyboo
I too am also interested in only the surround module, should I go ahead and fill out the form and leave that as a note?
Reply 70 of 228, by GL1zdA
What is the fastest CPU known to work well with the Adlib Gold?
getquake.gif | InfoWorld/PC Magazine Indices
Reply 72 of 228, by keropi
on a sidenote I can offer no more extra surround modules atm
I just don't have spares , the yamaha surround chips are just enough for the goldlibs planned
I will investigate if the chips source has more of them and if there are I will offer individual modules when I get them
all testing is done on a 386DX40 system - I would assume a 486DX33/40 would also be good *depending on the actual system* but I would not go higher
if the MMA chip crashes it's timers because of system speed then nothing will work on the gold
Reply 73 of 228, by GL1zdA
What about the MIDI cable? Is a special "Adlib" MIDI cable needed for the Joystick port? Because I've seen videos reporting problems with a typical Joystick-Midi cable.
Reply 74 of 228, by JimWest
GL1zdA wrote on 2022-10-20, 09:30:
Yes, a special „AdLib“ MIDI cable is needed. It’s the very same implementation as the original card.
But the pinout of that cable is still a mystery. We didn’t investigate it. So if someone got an original AdLib Midi cable, please get in touch with us.
Reply 75 of 228, by GL1zdA
How long should it take between submitting the form and getting a confirmation?
Reply 76 of 228, by keropi
goldlib is EXACTLY the same as the original, so the same problems will exist
if we had an original midi cable we could clone it as well but I have not even seen pictures of it...
it is not a big loss anyways IMHO as the interface is not a "proper" MPU-401 one and need specific adlib gold support from programs *AFAIK* (well at least this is state in the manual)
also I reply emails in the evening because I packets need to be made on working hours 😀
it's just the first days like this when the initial rush happens
Reply 77 of 228, by OriginalDan
will blank pcbs be avalible with a bom? for those of us with no so great currency conversion rates 🤣
Reply 78 of 228, by keropi
there is no thoughts to release blank pcbs... the cpld needs programming, the rare chips need sourcing and finally the end card could need some troubleshooting because it uses old chips
it's just not feasible to offer this as a kit/project even with the rare chips bundled
Reply 79 of 228, by OriginalDan
ah bummer. but fair enough, i hope there's a backup plan to account for the bus factor
