First post, by LightNingzZ
I can play the game but the speed goes too fast or too slow when I change it....How can I set it to the required speed? can't really play like that 🙁
Thanks for helpers :]
then don't change the speed adjustment key at all then
And play with unplayable speed?
Really smart 🙁
Don't change it? According to you it runs fine if you don't change it. That's what leileilol was commenting on.
I ment the speed is NOT OK atm...
I wanted to change it to normal playable speed...
Now can someone really help ? 🙁
Try typing CYCLES MAX 80% at the dosbox Z:\> prompt before running the game.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Tried..it's still slow as hell 🙁
If I type less % or more it will change the speed?
tried some didn't work 😦
What is the type and speed of your processor?
Aw..the worst.
I got intel processor 256 ram 1.5 gigahz..
geforce 2 mx
What dosbox version? What OS?
I'm using dosbox 0.65 I saw some replies saying it;s better than 0.7..
XP SP2
Well try 0.70 and see yourself. Maybe you'll like the speed improvement though.
Hmm..now I use dosbox 0.7 and magic carpet works with playable speed..
but no sound is set and it will crash if i'll touch the details
what build should i use?
And 1 more thing..can I invert mouse? :0
Reinstall the game within dosbox and be sure to select the correct
sound card with the right settings (irq=7, dma=1).
dosbox does not provide a way to invert the mouse axes, maybe the game does.
[Moved]
Intel i7 5960X
8 GB DDR4 (2100)
Where i select that details you wrote?
And what you mean by "install"? i just mounted c:\ and entered c:\CARPET
CARPET.EXE that's all 😦
Um i doubt the game came preinstalled, check your original disks.
Damn.
One of the things that makes the VOGONS website much nicer than all the other wanna-BEs out there is that fact that the message area is not overrun with garish and large picture sigs. The avatars should be enough.
Could the next version of the VOGONS web-site eliminate images such as those emplaced by LightNingzZ? 😒
Just my 2 cents,
dvwjr
Right-click "AdBlock Image".
haha..
