First post, by xeiter
Hi all,
I have two systems out of which the 486 system outperforms the P100 system in 3dBenchmark. So I wanted to check with the community if it is how it is supposed to be or something is wrong.
- 486dx4-100 , 16MB RAM, 256KB Cache, S3 Trio 64 V+
https://stason.org/TULARC/pc/motherboards/D/D … 86-EXP8449.html
- Pentium 100, 32MB, 256 Cache, S3 Trio 64 V+
https://stason.org/TULARC/pc/motherboards/F/F … 6F56-VER-1.html
I used 3Dbenchmark with the HAL bouncing letters in the video test and the 486 system outperforms the P100 system which seems odd to me.
The 486 system scored 66 and the P1 scores 50.
Does this seem normal to you? Am I missing something?
I tried overlocking the P100 to 120 (by setting multiplier to 2x instead of 1.5x) but the PC hangs after a few seconds. I also tried changing teh S3 video card to Tseng Labs ET6000 and observered similar results.
I checked the mobo jumpers and the p100 system is set to 66mhz with the 1.5 multiplier. Both systems have 256 cache.
In the system information program the p100 system reports 65Mhz (not 100). The BIOS post shows 100mhz.
Both systems are working stable and are using the same AUTOEXEC.BAT and CONFIG.SYS files and run 6.22.
Your help is appreciated.
Kind regardsm,
Anton
Reply 1 of 10, by leileilol
You're missing Quake. 😀
But yeah, that P100's underperforming somewhere.
Debian's fucked
Reply 2 of 10, by kolderman
Software needs(ed) to be optimized for P5.
Reply 3 of 10, by mpe
Yes. There is nothing wrong. Many simpler benchmarks and games like Doom run faster on a tuned late 486. The Pentium architecture with superscalar execution units, branch prediction, deeper pipelines, split-cache architecture, etc.needs certain complexity of software to show it muscles. P100 is objectively faster, just not at everything.
Blog|NexGen 586|S4
Reply 4 of 10, by xeiter
Thank you, all.
Reply 6 of 10, by darry
Something is probably off with the Pentium machine. I suggest you try other benchmarks.
Also, I believe this motherboard chipset (SIS 5511 or 5513) might be one of those that actually supports running with a single 72-pin. If this is the case and you are running with a single SIMM, this may explain the performance.
Reply 7 of 10, by Horun
Agree darry.
xeiter wrote on 2022-10-23, 20:39:
You give lots info on the 486 board but nothing on the Pentium board ( no picture, no link) and what version of 3dBenchmark so is hard to say why such a difference.
A good P-100 should out perform a 486DX-100 by nearly 50% unless you compare good to inferior products...
Can you post picture/link to the pentium board AND run cachechk on both and post pictures. something is off but not sure why.. just my opinion.
good comparison of Pentium 66 versus AMD 486-133 under different tests is this: https://www.youtube.com/watch?v=tm5lIQ_47Ko
Reply 8 of 10, by alvaro84
On a side note, 3dbench is heavily video speed dominated. What do these boards give in landmark or speedsys in this categori with those cards? I suspect the P5 result will be abysmal while, if my memory serves, the EXP8449 had top notch PCI speed for a 486.
Shame on us, doomed from the start
May God have mercy on our dirty little hearts
Reply 9 of 10, by rasz_pl
https://dependency-injection.com/early-pentium-chipsets/ SiS 5511 is surprisingly not terrible, at least in Abit PG5. But there is potential for 50% performance difference between terrible and excellent P100 board.
Reply 10 of 10, by xeiter
Hey, I didnt have photos - sorry about that.
I took some photos now - please see them below. After I assembled the PC back I thought: "Hmm what if I load just bare DOS 6.22 without anything in autoexec.bat and config.sys. So I did that and P100 returned much better results. My autoexec.bat and config.sys are very raw - I just got them off some CD that helped me to get my machines going. I still have lots of work to do with setting things up.
I just started getting back into retro pcs and dont remember many things from 90s. I guess loading stuff on boot like memory managers does affect things and skew test results.
I am now getting 71 for 486 and 91 for P100 in 3dBenchmark 1.0.
Below are the photos - maybe someone can pick something up that I am still missing:
https://stason.org/TULARC/pc/motherboards/F/F … 6F56-VER-2.html
Thank you for your help.
Horun wrote on 2022-10-24, 02:03:
Agree darry. […]
Agree darry.
