Reply 900 of 1037, by red-ray
GL1zdA wrote on 2022-10-24, 21:26:
AIDA64 reported my 900 MHz Xeon running at 5x180 MHz
It's a bug in AIDA64, I expect its only using 4 bits when it should be using 5 bits. It's nothing to do with the MB jumper settings.
The multiplier comes from MSR 0000002A (EBL_CR_POWERON) and for Coppermine or Cascades CPUs >= stepping 0x03 it's 5-bit rather than a 4-bit value with x9.0 being 0x10. To convert this value to the multiplier SIV has a 32 entry vector with 0x00 -> x5.0 and 0x10 -> x9.0.
I recall SIV also having an issue before I fixed it, the SIV bugette was always using a 5-bit value for Cascades.
Reply 901 of 1037, by Irinikus
red-ray wrote on 2022-10-24, 20:25:
I noticed the speed reported by CPUZ 1.74 looks to be incorrect, I assume it should be around 1000 MHz rather than 1138.81 MHz, should it? I am also wondering if this has been fixed in CPUZ 2.03.0.x32, has it?
The newer version does indeed report it correctly!
YouTube
Reply 902 of 1037, by red-ray
GL1zdA wrote on 2022-10-22, 22:13:
I can wait for the next beta to test it.
Irinikus wrote on 2022-10-24, 11:05:
Here's the SGI Visual Workstation 320
I have just uploaded SIV 5.67 Beta-07 which should report the half the Xeon CPU temperatures and the GPU on Windows 2000, does it please?
I am not sure which Xeon CPU each temperature is for, maybe you could figure it out by trying just one CPU in each of the four slots if that is possible. Basically I need to know which SMBus address is used by each slot.
Irinikus wrote on 2022-10-25, 04:55:
Thank you for checking and I suspected it would. I will be surprised if CPUZ reports a GPU, does it please?
Reply 904 of 1037, by red-ray
Irinikus wrote on 2022-10-28, 16:44:
CPUZ unfortunately didn't show any GPU information!
This is the information I was able to get for you though:
Thank you for confirming CPUZ did not report a GPU, but what about SIV 5.67 Beta-07? I suspect/hope it did so please may I have new save files so I can check how what SIV reports compares to the screen shots?
Most of the information reported by the screen shots should be on Menu->Machine->GPU Info and/or Menu->Machine->Graphis.
Reply 905 of 1037, by GL1zdA
Here's the report from the new beta on Windows 2000.
Not sure why it shows CPU2 and CPU3 in the "Machine" section - currently only 2 are installed and this is what SIV shows on the "front" page.
It reports 0-bits for the graphics memory bus. The memory bus in this system is 256-bit (always, both VW320 and VW540).
This will be probably my last report, since tomorrow someone will pick this system up. I will make him aware of this thread.
    14.96 KiB
    SIV V5.67 Beta-07 GPU Information for a Visual Workstation 540
    SIV V5.67 Beta-07 VW540 report.zip
    140.83 KiB
    35 downloads
    SIV V5.67 Beta-07 public report for a Visual Workstation 540
    32.21 KiB
    SIV V5.67 Beta-07 Machine page for a Visual Workstation 540
    31.51 KiB
    SIV V5.67 Beta-07 main window for a Visual Workstation 540
getquake.gif | InfoWorld/PC Magazine Indices
Reply 906 of 1037, by red-ray
GL1zdA wrote on 2022-10-28, 20:29:
Thank you for checking out Beta-07 and posting the results. All the adjustments I made worked as I hoped they would.
The [Machine] panel reporting CPU-2 + CPU-3 is down to the system BIOS incorrectly setting these in the SMBIOS data, it's the standard Garbage In -> Garbage Out. This is not the only error I spotted, Pentium II should be Pentium® III Xeon™, Slot D, Banks 11-15 should be Slot D, Banks 12-15, I suspect 5.0ns (200MHz) should be 10.0ns (100MHz) and further down after Slot C Banks 8-11 there should be Slot D Banks 12-15. I also have my doubts about Bits 48
0-bits means SIV does not know how many bits, further it's also reporting ISA which I expect is incorrect, what should it be? Given time I could improve what gets reported, but not before tomorrow. One thing that would be handy is a registry export of HKLM\System\ControlSet001\Services\Sgcomp\Device0.
gpu-inf.png - I think is not what you intended to post
Reply 907 of 1037, by GL1zdA
I'm attaching the registry export.
There are definitely no ISA slots, I guess it might see something from the Intel PIIX4E.
All the "odd"devices (audio, graphics, video, including digital I/O, firewire) are attached directly to the chipset, basically part of it, not via PCI, so I guess that's why they are "undetectable" or misdetected as ISA.
I've also updated the gpu-information picture in the previous post.
    sgcomp.zip
    571 Bytes
    29 downloads
    Visual Workstation sgcomp registry export
Reply 908 of 1037, by red-ray
GL1zdA wrote on 2022-10-28, 21:58:
Thank you. I checked what is available, there is nothing I have not seen before and SIV has reported "HardwareInformation.ChipType" + "HardwareInformation.DacType"+ "HardwareInformation.AdapterString" + "HardwareInformation.MemorySize" long time. I was hoping there was other information.
Reply 910 of 1037, by GL1zdA
Irinikus wrote on 2022-10-29, 04:42:
Here's what the latest version shows: […]
Maybe for the GPU Information to show anything, you need a specific Windows Update? The machine I was running SIV on had all updates installed.
For those curious, here's the Graphics info for the 1600SW panel
    11.16 KiB
    No downloads
    SIV V5.67 Beta-07 Graphics info for a SGI 1600SW LCD
Reply 911 of 1037, by red-ray
Thank you, something is strange as on the 540 running Windows 2000 it reported as below.
file.php?id=148719
Please will you post a registry export of HKLM\HARDWARE\DEVICEMAP\VIDEO. Within this there should be \Device\Video0 and maybe others with the data being similar to \Registry\Machine\System\ControlSet001\Services\Sgcomp\Device0 so also export whatever it points to, in this case it would be HKLM\System\ControlSet001\Services\Sgcomp\Device0
It would also be helpful if from a command window you did SIV32L -DBGGPU -DBGOUT > SIV_DBGOUT.log and attached the generated SIV_DBGOUT.log
Reply 912 of 1037, by GL1zdA
The second device is the Mirror Driver.
    devicemap-video.zip
    937 Bytes
    29 downloads
    Devicemap Video
Reply 913 of 1037, by red-ray
GL1zdA wrote on 2022-10-29, 10:26:
Thank you, your 540 is as I expected and SIV reported the GPU, it's the 320 information that I need to see.
The attached SIV32L V5.67 GPUs-08 test SIV should do a rather better job of reporting the GPU on your 540, does it?
Do you know what the GPU RAMDAC is and/or it's speed please?
Reply 914 of 1037, by GL1zdA
I see it reports now the memory speed for the GPU.
As for the RAMDAC, I think it's integrated, at least I can't identify anything on the motherboard that looks like one.
    14.7 KiB
    SIV V5.67 Beta-08 test GPU Information for a Visual Workstation 540
    30.74 KiB
    SIV V5.67 Beta-08 test main window for a Visual Workstation 540
Reply 915 of 1037, by red-ray
GL1zdA wrote on 2022-10-29, 11:12:
It also says MCH rather than ISA and the description is now Cobalt Graphics. It should also report the core clock as 100 MHz and 256-bit memory.
Reply 916 of 1037, by GL1zdA
Yes, it works!
    14.66 KiB
Reply 917 of 1037, by red-ray
GL1zdA wrote on 2022-10-29, 13:06:
Yes, it works!
No, it half works, please try one of the later SIVs I have posted.
I got the # ROPs from http://swarm.cz/gpubench/_GPUbench-results.htm
Reply 919 of 1037, by red-ray
Irinikus wrote on 2022-10-29, 14:32:
Here's the registry file:
Thank you, so far so good, I can see \Device\Video0 is \REGISTRY\Machine\System\ControlSet001\Services\Sgcomp\Device0 which is what I expected.
I also need the registry export of HKLM\System\ControlSet001\Services\Sgcomp\Device0 as SIV must have an issue with whatever it contains.
