Problems with System Shock 1 on dosbox 0.70
First post, by v0g0ns
Hi, I'm new to the forum, and have a few questions or problems when running System Shock 1 on dosbox 0.70. I managed to install and run the game from dosbox 0.70, runs great at 640x480, but at moments, the colors all change, flash into these bright display of colors that mess up the entire screen. If I knew how to take a picture of the in game problem, I would show you. Does someone know how to solve this? The game at some point exited to the dos prompt abruptly. Another problem, or, well instead a question, is how do I change the key assignment in the game? I would like to use the wasd key combo to move around, and would the game run faster if I increased cpu cycles?
Thanks in advanced for your help,
Reply 1 of 24, by v0g0ns
edit: I read the readme and found out how to take a screenshot, so here it is. Turns out, it not only changes the colors, but on the dosbox console lotsa illegal read errors show. Does someone know what could the problem be? I really would like to play this classic on my pc!
Reply 3 of 24, by v0g0ns
Thank you for replying to my post. Well, I have only tried it when dosbox is at fullscreen. I'm looking at the dosbox.conf file, dont know which values for output to use. Do you have any recommendations?
Reply 4 of 24, by DosFreak
overlay or ddraw if your using the official DosBox 0.70.
If you installed your video card's official drivers then you can try opengl.
Try it in a window and see if that has any effect.
Make your games work offline
Reply 5 of 24, by v0g0ns
Well, I'm using the official dosbox .70 and have my video card's official drivers. I tried with ddraw and opengl and the color palette still goes wrong.
Reply 6 of 24, by ErikGG
Did you set any "compatibility options" in XP like only 256 colors and so on?
If so, then uncheck these for DOSBox.
Erik.
Read the new FAQ.doc
Reply 8 of 24, by v0g0ns
Come to think of it, maybe it's because I have system shock in sub directory from where dosbox is installed. Is that ok?
Rise of the Triad forum
Reply 9 of 24, by v0g0ns
Here´s another screenshot of the problem. Maybe it's a video driver problem?
Apparently it occurs with VGA mode 640x480, which is the mode in which i would like to play ss1
Reply 10 of 24, by wd
Rank DOSBox Author
DOSBox Author
Is this a dosbox-internal screenshot (ctrl-f5 or what it is)? If so then it's
a bug in the emulation or something.
Does it occur in fullscreen only?
Reply 11 of 24, by eL_PuSHeR
Have you tried forcing use of a different video mode, maybe 800x600?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 12 of 24, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
strongly hints to a problem inside DOSBox.
1+1=10
Reply 13 of 24, by v0g0ns
Yea, it's an internal screenshot I took with ctrl-f5. Could it be a bug within dosbox? Yes, this is when in fullscreen mode. How do I force a different resolution, like 800x600?
Reply 14 of 24, by Qbix
Rank DOSBox Author
DOSBox Author
if you have read errors then a different output/forced resolutions doesn't help.
have you tried changing the sound settings of the game ?
Water flows down the stream
Reply 15 of 24, by v0g0ns
Which settings should I use for sound? You mean in the setup program, right?
Reply 16 of 24, by wd
Rank DOSBox Author
DOSBox Author
Yep, disable it through setup.exe or install.exe
Further try with ems/xms disabled, try loadfix.
Reply 17 of 24, by v0g0ns
Im sorta a newbie with dosbox, how do I disable xms/ems and use loadfix?
Reply 18 of 24, by wd
Rank DOSBox Author
DOSBox Author
See the dosbox.conf, or type "xms false" etc. in the dosbox window.
