Reply 23060 of 31478, by Kahenraz
I bought a Radeon X800 Pro that ended up being defective (completely dead). A visual inspection showed a single capacitor missing near the PCI-e edge connector, which looked like an easy repair. After looking at the card under a microscope however, I kept finding more and more broken or missing components all across the board.
I found and replaced what I think was all of the damage, also checking various traces that appeared to be damaged, but I wasn't able to revive it. The damage to this card was significant, and it's condition is overall extremely poor.
Can't save them all.
The attachment 20221104_052604_resize_21.jpg is no longer available
The attachment 20221104_052617_resize_90.jpg is no longer available
The attachment 20221104_052635_resize_7.jpg is no longer available
The attachment 20221104_052706_resize_20.jpg is no longer available
The attachment 20221104_091357_resize_34.jpg is no longer available
Reply 23061 of 31478, by Kahenraz
More pictures of the damage.
The attachment 20221104_080449_resize_45.jpg is no longer available
The attachment 20221104_055341_resize_30.jpg is no longer available
The attachment 20221104_063810_resize_78.jpg is no longer available
The attachment 20221104_061116_resize_48.jpg is no longer available
The attachment 20221104_080131_resize_43.jpg is no longer available
Reply 23062 of 31478, by Thermalwrong
That's a shame, it looks like a few of the PCI-e traces are scratched up or damaged as well as those components, I've got an X1950AGP in a similar state that came from a recycler / gold scrap lot. I haven't tried powering that up yet.
Today I was trying to make a flat flex cable that has contacts facing up on one end and down on the other. I didn't want to wait for them from China and I've got several cables that have both ends facing the same way. The solution turned out to be pretty cool literally. Heating the flat flex cable just destroyed it - it's 0.5mm pitch and the pins ended up all over the place. So instead, I got two cables and soldered them together using low-melt solder at like 140C instead of the usual 250+C. That stopped the cable from melting and the low melt solder is adhering the pins nicely.
Trying to troubleshoot why my GuS isn't making MIDI in games I was trying another one of my Advantech SBCs but it needed a new LCD adapter - I got 5x of them from JLCPCB for like £12 along with another design which is more than I'll ever really need. Those connect a parallel LCD via flat flex cable (and adapters sometimes) to the Advantech LCD connector, but the one that worked on my PCM-4825 did not work on my PCA-6145. It would display but it was just beeping? Then it locked up.
I should really check the pinouts of connectors before I power things up! 😁 I found the PCA-6145's 44-pin LCD connector has keyboard signals (??) where I'd put a ground pad and that was pulling one of the keyboard signals to ground and just messing everything up. The PCB looks far less nice than the unmodified design but at this rate every one of my Single Board Computers will be able to easily have an LCD natively connected to it.
Reply 23063 of 31478, by Kahenraz
Fixed up this other Radeon X800 Pro successfully. It might not be visible from the photos, but there was a lot of cleaning to be done. I also soaked the heatsink in vinegar and scrubbed it, applied new thermal paste and pads, and revived the scratchy fan with a few drops of oil.
The attachment 20221104_043234_resize_4.jpg is no longer available
Reply 23064 of 31478, by Shponglefan
Spent some time this evening tinkering with my 386 DX-40 and 486 DX/2-66 systems, still trying to figure out sound card options for these respective systems.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 23065 of 31478, by Shponglefan
Kahenraz wrote on 2022-11-05, 02:42:
That's a lovely restoration/cleaning. Looks almost brand new in that second pic.
Reply 23066 of 31478, by RandomStranger
I went back poking at the Vectra, installing some game demos, testing the limits of the on-board Matrox G200. It's a lot more disappointing than expected. I hear people saying it's the first half way decent gaming GPU from Matrox. I guess it's better than a Trio3D, it runs Quake 3 Arena at 17-18fps on default settings. On the other hand a lot of games won't start or freeze in 3D accelerated mode and Powerslide looks like this:
The attachment Powerslide.png is no longer available
According to youtube, this -or at least discrete variants of this (1) (2) (3)- should perform much better. Even if it's slower than the discrete variants, it should at least run/display games correctly, is it not? Maybe the issue lies elsewhere? Or did I just pick an unlucky batch of games to test?
The attachment IMG_20221105_191941.jpg is no longer available
Edit:
Might be an issue of driver version? Booted into Windows 2k. Quake 3 is a little bit faster, ~21fps, Carmageddon 2 demo this time works and runs decently, Powerslide however does not launch. Returns to castle Wolfenstein also runs alright. About as slow as expected.
Reply 23067 of 31478, by Shponglefan
Tried to repair a Toshiba 6x CD-ROM today.
It seems to suffer from slipping the gears when trying to open the unit and consequently won't open.
Disassembled it to the point picture, cleared it up, reassembled but still have the same issue. I'm going to try disassembling again, but there is a lot of finnicky plastic so I'm a bit concerned about disassembling the motor and gear assembly.
Anyone else have tips on trying to repair a drive like this? Is it worth attempting or should I just opt for a different drive?
Reply 23068 of 31478, by Kahenraz
RandomStranger wrote on 2022-11-05, 18:34:
I didn't have good results in OpenGL games until I used the g200icd.dll ICD from the XP driver. See here:
DirectX and OpenGL problems with my Matrox G200?
You also need to be aware that it does not support multitexturing at all, and still display bright or messed up textures in games like Unreal, unless it is disabled.
Reply 23069 of 31478, by pentiumspeed
Replaced the 8 SDRAM ICs on Voodoo3 3000 with brand new ICs from USA seller on ebay and jailbars is gone! Now I can go on and test it but no windows 98se disc yet. Where to get one?
Cheers,
Great Northern aka Canada.
Reply 23070 of 31478, by Nexxen
5 cpus I tested actually work.
From a left for dead batch of 20+ it's good.
I still hate socket A though, I hate it like Dr. Cox hated Dr. Kelso.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 23071 of 31478, by Standard Def Steve
The cloud infrastructure directly above my house dumped a ton of snow on us today, so I stayed inside and did cozy computer stuff. My greatest accomplishment? Why, the yearly backup of my 486, of course! An up-to-date copy of both hard drives--that's 1.1GB of DOS gaming goodness--now safely resides on my file server.
It sure took a while (my my, is DOS networking ever slow!), but all I have to do now is blast off to the planet Tuul in my Bean w/ Bacon Megarocket and mow down some nasty goblins, baby!
"A little sign-in here, a touch of WiFi there..."
Reply 23072 of 31478, by BitWrangler
Cloud delivery, what will they think of next, hopefully they will progress from various forms of H2O to beer at least soon.
Reply 23073 of 31478, by zPacKRat
it used to be yellow.
Reply 23074 of 31478, by appiah4
InWin A500 *Heart*
Reply 23075 of 31478, by RandomStranger
In recent month I didn't write about the monthly vintage market. I went to all of them, but they were pretty boring regarding vintage electronics. Today however I got to pick up something.
The attachment IMG_20221106_115307.jpg is no longer available
The attachment IMG_20221106_115318.jpg is no longer available
An ABIT Media XP 5.25" front panel. A little dirty and I don't have an ABIT *T MAX series mainboard, but the USB connectors seem to be standard so probably the card reader and USB ports work with non-compatible boards and I hope that at least the mic and headphone jacks can be used with a modded cable. The S/P DIF output and the IR receiver are probably out of the question without a compatible board. Not that I found it's remote controller. Otherwise it's a little dirty, but looks to be undamaged.
Off-topic purchases
The water bottle is similar to one I already had, but twice as big. I use them when hiking, and I'll probably use this bigger one in the gym too. The shakers I used until now always leak and the plastic bottles I was using in the past often broke. The little one I had already proven itself.
The brush is retro related, I picked it up from the same place to clean retro hardware.
The business card holder is to hold cards. The right size for personal ID card, driving license, credit/debit cards and others of similar size.
The plates are some very heavy stuff. Sadly there weren't a full set, so I picked one each. Will be good for serving snacks when I have guests over.
The attachment IMG_20221106_115649.jpg is no longer available
As for these pictures ,they are printed on iron plates. I like these vintage/vintage inspired pinup images. I already had some decorating my kitchen. I think I'll make get something fixed to the wall having some neodymium magnets to make it easier to switch them. I thought that maybe the bathing girl should be in the bathroom, but I'm concerned it'd start to rust in the humid air.
The attachment IMG_20221106_115842.jpg is no longer available
It was only after I purchased that I noticed the cowgirl is a horsegirl, but I don't mind, it still looks good.
Reply 23076 of 31478, by PcBytes
Revived an ASUS P5PE-VM. Turns out some of the MOSFETs got hot and desoldered themselves. A few hours later they started working.
Now, to rebuild that period correct Raidmax/Rhino RX-500Y PSU, and I might be on track for a nice retro build w/ a Pentium Dual-Core E2xxx 😀
Reply 23077 of 31478, by liqmat
appiah4 wrote on 2022-11-06, 11:39:
InWin A500 *Heart*
I swear these cases are breeding. I picked up five or six NIB units back in 2018 as you might remember. Then another guy picked another dozen or so in Texas about a year later. Another guy supposedly finds over a dozen from a Chinese seller. They just keep turning up. Only thing I can think of is they were late run cases when black cases were becoming more fashionable. I had to give my last one up a couple of years ago due to travel and the weight of the thing.
Reply 23078 of 31478, by appiah4
Overseas shipping is restrictive for me, I need to find one locally.. Long shot 🙁 At least I found an Elan Vital T10.
Reply 23079 of 31478, by zPacKRat
InWin A500 *Heart*
Just a quick note, I bought it new for my first diy build back in the late 90s. While I've gotten rid of a fair bit of old gear over the years,for some reason I didn't get rid of the a500.
