HDD Led activity on DOS
First post, by Santyago
I have a problem with the constant lighting of the hdd led activity on DOS. This is normal?
The problem does not occur in DOS 6.22 and after running Windows, but back to DOS, led lightng constant again.
  • Pure DOS 6.22 - is ok
  • Pure DOS from W95 and W98 - constant lighting
  • On running W95 and W98 - is ok
  • After quick from W98 to DOS - constant lighting
Reply 1 of 9, by konc
No, of course it isn't normal.
If you run something that triggers the led, eg. a simple dir, does it get unstuck?
Reply 3 of 9, by Santyago
Only pure 7.1 DOS from Windows 98. Maybe SmartDrive is emebeded in DOS7?
Reply 4 of 9, by czeci
Hi, I got the same problem, even worse because HDD LED is active since power up and only go off when Windows 98 is fully loaded, so DOS 6.22 or 7.1 in command prompt makes HDD LED stuck at active ..and it doesn't matter if I load any program or search in folders it's just shining red.
Reply 5 of 9, by Rwolf
Maybe too little ram, constant swapping - esp if DOS is launched from within windows?
Alternately some file compression on the partition in windows that takes place in the background?
Reply 6 of 9, by Azarien
Is the LED constantly lit without any pulsing (which may indicate electric problem) or flashing rapidly, which suggests HDD activity?
No it's not.
Reply 7 of 9, by badmojo
I had this issue and it was caused by my CD-ROM drive - if you have one installed then try not loading the driver and see if that makes a difference. If it is that, then there's a little app that resets a CD-ROM drive and that fixed it for me. CDBEQUIET or something like that?
Reply 8 of 9, by Santyago
Nope. Without CDROM that same situation. Strange.... in pure DOS 6.22 is ok, in pure 7.1 not
Reply 9 of 9, by czeci
badmojo wrote on 2022-11-07, 05:42:
Thanks, disconnecting optical drive fixed the issue, so the next issue to fix is that I missing optical drive now 😁
