First post, by filipetolhuizen
- Oldbie
Hello,
Has anyone tried modding newer drivers to support the older GTX460? If anyone has been successful, which is the newest working drivers for it? OS would be Win7 64 bits. Thank you.
Hello,
filipetolhuizen wrote on 2022-11-15, 23:36:Hello,
Isn't GTX460 already supported on Win7? What feature do you need from newer drivers?
LSS10999 wrote on 2022-11-16, 00:36:filipetolhuizen wrote on 2022-11-15, 23:36:Hello,
Has anyone tried modding newer drivers to support the older GTX460? If anyone has been successful, which is the newest working drivers for it? OS would be Win7 64 bits. Thank you.Isn't GTX460 already supported on Win7? What feature do you need from newer drivers?
It is supported, but I cannot get some GOG re-releases to work. Their minimum requirements only mention DX 11 support for graphics, which the GTX460 handles.
filipetolhuizen wrote on 2022-11-20, 01:46:LSS10999 wrote on 2022-11-16, 00:36:filipetolhuizen wrote on 2022-11-15, 23:36:Hello,
I don't understand. Fermi already had support for DX11... What error did you encounter exactly?
LSS10999 wrote on 2022-11-20, 04:35:filipetolhuizen wrote on 2022-11-20, 01:46:LSS10999 wrote on 2022-11-16, 00:36:Isn't GTX460 already supported on Win7? What feature do you need from newer drivers?
Crashes on startup on a few remastered reissues (eg.: Chasm: The Rift). I also have random crashes during gameplay on very few non-remastered reissues (eg.: SpeedBusters). None of them has been reported by other customers.
filipetolhuizen wrote on 2022-11-20, 17:27:LSS10999 wrote on 2022-11-20, 04:35:filipetolhuizen wrote on 2022-11-20, 01:46:It is supported, but I cannot get some GOG re-releases to work. Their minimum requirements only mention DX 11 support for graphics, which the GTX460 handles.
I'm not sure about the titles you're playing. What exactly are the requirements for the remastered versions?
It only came up to me recently that Win10 introduced some different DLLs in regards to DirectX and such, that are incompatible with older Windows including Win7. So if the game explicitly stated Win10 as a minimum requirement then there is a chance Win10-specific DLLs are being used. For some symbols there were suggestions about modding the executable using CFFExplorer to point to the corresponding Win7 DLL/API, but there's no guarantee things would work afterwards, as one may eventually hit a wall against a Win10-exclusive symbol that does not have a corresponding match for Win7.
As for non-remastered ones, I'm not really sure if these titles were having issues with Win7 and onwards since the very beginning, as the crashes may or may not be related to video cards so more details are needed...
LSS10999 wrote on 2022-11-21, 01:39:I'm not sure about the titles you're playing. What exactly are the requirements for the remastered versions? […]
filipetolhuizen wrote on 2022-11-20, 17:27:LSS10999 wrote on 2022-11-20, 04:35:I don't understand. Fermi already had support for DX11... What error did you encounter exactly?
Chasm: The Rift minimum requirements:
System: 64-bit Windows 7 / 8.1 / 10 / 11
Processor: Dual Core 2Ghz Processor
Memory: 4 GB RAM
Graphics: DirectX 11 compatible for 1920×1080
DirectX: Version 11
Storage: 2 GB available space
Requires a 64-bit processor and operating system
(Nothing on my system is below that)
Speed Busters minimum requirements:
System: Windows XP or Vista
Processor: 1.8 GHz
Memory: 512 MB RAM
Graphics: 3D graphics card compatible with DirectX 7 (compatible with DirectX 9 recommended)
Storage: 2GB HDD
(Again, nothing on my system is below that)
filipetolhuizen wrote on 2022-11-21, 01:49:Chasm: The Rift minimum requirements: System: 64-bit Windows 7 / 8.1 / 10 / 11 Processor: Dual Core 2Ghz Processor Memory: 4 GB […]
filipetolhuizen wrote on 2022-11-20, 17:27:Crashes on startup on a few remastered reissues (eg.: Chasm: The Rift). I also have random crashes during gameplay on very few non-remastered reissues (eg.: SpeedBusters). None of them has been reported by other customers.
Memory: 4 GB RAM
DirectX: Version 11
(Nothing on my system is below that)Speed Busters minimum requirements:
Processor: 1.8 GHz
Memory: 512 MB RAM
Storage: 2GB HDD
Okay so everything's within requirement... What kind of error?
Something like "xxx has stopped working"?
If that's the case you may be able to find some hints from Event Viewer -> Application. If the game is able to produce a crash log/dump it may also be helpful in pointing out which exactly was crashing it.
LSS10999 wrote on 2022-11-21, 03:18:Okay so everything's within requirement... What kind of error? […]
Memory: 4 GB RAM
DirectX: Version 11
Processor: 1.8 GHz
Memory: 512 MB RAM
Storage: 2GB HDD
(Again, nothing on my system is below that)Okay so everything's within requirement... What kind of error?
Exactly, but I don't think Event Viewer clues are clear to me.
Here are some reports from November the 2nd when I tried some config tips (none of them made the game work):
Nome de aplicativo com falha: Chasm.exe, versão: 0.0.0.0, carimbo de hora: 0x634ef4a0
Nome do módulo de falhas: Chasm.exe, versão: 0.0.0.0, carimbo de hora: 0x634ef4a0
Código de exceção: 0xc0000005
Deslocamento com falha: 0x00000000000b239a
Identificação do processo com falha: 0x23c0
Hora de início do aplicativo com falha: 0x01d8eede75f81a58
Caminho do aplicativo com falha: D:\Filipe\Chasm The Rift\Chasm.exe
FCaminho do módulo de falhas: D:\Filipe\Chasm The Rift\Chasm.exe
Identificação do Relatório: b9496898-5ad1-11ed-b30c-305a3a040cbf
Identificação do processo com falha: 0x25e8
Hora de início do aplicativo com falha: 0x01d8eedeb2cd297d
Identificação do Relatório: f2ac057d-5ad1-11ed-b30c-305a3a040cbf
Identificação do processo com falha: 0x2368
Hora de início do aplicativo com falha: 0x01d8eedebf36fcee
Identificação do Relatório: fddfc9ee-5ad1-11ed-b30c-305a3a040cbf
Identificação do processo com falha: 0x1bac
Hora de início do aplicativo com falha: 0x01d8eedef2ff0fa3
Identificação do Relatório: 31c01f93-5ad2-11ed-b30c-305a3a040cbf
filipetolhuizen wrote on 2022-11-21, 03:36:Exactly, but I don't think Event Viewer clues are clear to me. Here are some reports from November the 2nd when I tried some con […]
Memory: 4 GB RAM
DirectX: Version 11
Processor: 1.8 GHz
Memory: 512 MB RAM
Storage: 2GB HDD
Here are some reports from November the 2nd when I tried some config tips (none of them made the game work):Nome de aplicativo com falha: Chasm.exe, versão: 0.0.0.0, carimbo de hora: 0x634ef4a0
Identificação do Relatório: b9496898-5ad1-11ed-b30c-305a3a040cbfNome de aplicativo com falha: Chasm.exe, versão: 0.0.0.0, carimbo de hora: 0x634ef4a0
Identificação do Relatório: f2ac057d-5ad1-11ed-b30c-305a3a040cbfNome de aplicativo com falha: Chasm.exe, versão: 0.0.0.0, carimbo de hora: 0x634ef4a0
Identificação do Relatório: fddfc9ee-5ad1-11ed-b30c-305a3a040cbfNome de aplicativo com falha: Chasm.exe, versão: 0.0.0.0, carimbo de hora: 0x634ef4a0
It looks like the crash (segfault) didn't point to anything other than the game program itself.
You may try enabling compatibility modes, but I don't really know how that function works and that it never really worked for me before.
Which nVidia driver version are you using? If you think the newest driver may be faulty, you may try an older one.
LSS10999 wrote on 2022-11-21, 07:43:It looks like the crash (segfault) didn't point to anything other than the game program itself. […]
Identificação do Relatório: 31c01f93-5ad2-11ed-b30c-305a3a040cbfIt looks like the crash (segfault) didn't point to anything other than the game program itself.
I'm using the 391.35 drivers which is the latest supporting the GTX460. I thought of newer ones because they have fixes for newer releases and I've never seen anything break after upgrading the drivers on Win7.
filipetolhuizen wrote on 2022-11-21, 18:53:LSS10999 wrote on 2022-11-21, 07:43:It looks like the crash (segfault) didn't point to anything other than the game program itself. […]
So have you tried any older drivers? nVidia drivers can be a hit or miss that in some cases, newer drivers != better.
LSS10999 wrote on 2022-11-22, 00:48:filipetolhuizen wrote on 2022-11-21, 18:53:LSS10999 wrote on 2022-11-21, 07:43:It looks like the crash (segfault) didn't point to anything other than the game program itself.
Not yet, but I'm guessing the GTX460 doesn't meet the minimum requirements for some reason as none of the workarounds on the GoG forums worked for me.
Regarding Speed Busters, the original game was already way too buggy, but apparently, it has something to do with the car I choose. I'm able to finish a race with certain cars without any issues, but selecting other cars make the game crash even before finishing one lap.
filipetolhuizen wrote on 2022-11-22, 04:03:LSS10999 wrote on 2022-11-22, 00:48:filipetolhuizen wrote on 2022-11-21, 18:53:I'm using the 391.35 drivers which is the latest supporting the GTX460. I thought of newer ones because they have fixes for newer releases and I've never seen anything break after upgrading the drivers on Win7.
Strange... Fermi does have DX11 support so if it stated DX11 as requirement then there's no reason GTX460 shouldn't work on D3D API level grounds.
How about other cards within Fermi ranges, such as 400, 500 series and low-end 600 series? Had anyone with these cards reported similar crashes like the one you had, under similar environments (Win7 x64)?
If the particular issue affects every Fermi owner... then yes, there's concrete proof of incompatibility.
LSS10999 wrote on 2022-11-22, 05:33:Strange... Fermi does have DX11 support so if it stated DX11 as requirement then there's no reason GTX460 shouldn't work on D3D […]
filipetolhuizen wrote on 2022-11-22, 04:03:LSS10999 wrote on 2022-11-22, 00:48:So have you tried any older drivers? nVidia drivers can be a hit or miss that in some cases, newer drivers != better.
Regarding Speed Busters, the original game was already way too buggy, but apparently, it has something to do with the car I choose. I'm able to finish a race with certain cars without any issues, but selecting other cars make the game crash even before finishing one lap.Strange... Fermi does have DX11 support so if it stated DX11 as requirement then there's no reason GTX460 shouldn't work on D3D API level grounds.
On the GoG forums most users cards are not mentioned. One mentioned an AMD system. Only Win10 is mentioned as their OS. Strangely, DX12 is mentioned there instead of DX11.
