First post, by LeFlash
i've got the mentioned board, but unfortunately, the BIOS doesn't know the PII Overdrive.
It works, but is painfully slow.
Other 440FX-bioses work "roughly", but not stable or don't correctly support the Super-IO.
Does anyone know of a compatible BIOS with PIIOD support?
Or, how can i patch the detection in the current image?
simple as adding microcode? Or is there more work to do?
Kind regards
Stephan
Reply 1 of 3, by Horun
Your super IO is the SMC 37c669, if it were the Winbond or UMC more other P.Pro BIOS would support it.
The DFI 686IPA use the UMC, have Award bios and entries for Pentium Pro ODP...
Reply 2 of 3, by LeFlash
Thanks. CPU gets detected with 75MHz, but setup runs quite fast.
After the initial copy of W2K and the first reboot, it crashes with a bluescreen and random drivernames.
I'll try the board with a regular PPro, if it isn't working then, maybe there's something else wrong.
Reply 3 of 3, by LeFlash
Ok, board seems to have problem. Switched to a GA-686DX with same CPU and RAM, working perfectly fine.
Will check caps, maybe it's because of the black ppro (which is quite thirsty)...
