First post, by andy120
What type of chip is used for a award 32 pin, 27c or 29c? the numbers are gone on this one.
Powered by one Harris 286-12
What motherboard ? Most newer 32pin are 29c type or equal. You need to know if the board uses +5v or +12v for eeprom flashing (unless you a external programmer) AND the size.
Examples like Atmel AT20c010 (5v 1Mbit), SST 29EE010 (5v 1Mbit), Smos F29c5100 (5v 2Mbit), Intel P28F001 (12v 1Mbit).
its an asus pvi-486sp3. there could be csi on it. other than that, there is nothing. the manual says it has 12 and 5v for programming.
Ok your board uses a 1Mbit eeprom. From google images I see a few different BIOS chips. Atmel AT29c010 (5v VPP) on this: https://wiki.preterhuman.net/images/3/37/486sp3-1.jpg
An SST 27SF010 or 29EE010 on another, hard to read the micro print but is def an SST eeprom.
https://cdn11.bigcommerce.com/s-6bkt1ygjlf/im … c=2?imbypass=on
added: I meant AT29c010 in my previous post....
Ok. How do i write/convert the .awd file to something i can get written to a chip?
