First post, by Lynxman
I've got this Abit VH6T that I recapped and it still doesn't work. It also had a faulty BIOS ROM so I replaced that and progarmmed it but still doesn't work. After some closer inspection I found a blown IC under the BIOS IC so I suspect that's the fault. Possibly because someone inserted a BIOS backwards at some point, blowing both the BIOS IC and this IC. It looks like part of the part number may be blown off. All I can tell is F04 which may be an SN74F04 hex inverter. Does anyone have the same motherboard available to check for me? Maybe their IC has the full part number printed.
Reply 1 of 5, by Lynxman
I ordered some SN74F04 hex inverters. They look similar.
Reply 2 of 5, by computerguy08
Yes, that's a 7404 hex inverter
Reply 3 of 5, by mkarcher
computerguy08 wrote on 2022-11-26, 10:31:
And the "F" is likely important. The 7404 and 74F04 implement the same logic function (hex inverter), but the "F" variant is way faster. Vastly simplified, but usually good enough to understand 486 boards: You can use a 7404, a 74LS04 or a 74HC(T)04 at ISA speed, and you can use a 74ALS04, 74ACT04 or 74F04 at FSB speed.
Reply 4 of 5, by Lynxman
Thanks. I'm used to repairingolder stuff som 74hc04 is the kind of marking I expect to see.
I found an F04 on a graphics card and cannibalized it. Still no activity at all. I guess there are more blown ICs. I'm gonna remove the BIOS socket and remove the rest of the ICs to test them. It's a pain to work inside the DIP socket.
Reply 5 of 5, by computerguy08
mkarcher wrote on 2022-11-26, 19:35:
Agree, I was just referring to the generic 74xx type of the IC. Needs to be at least the "F" type or faster so it matches the original part.
