First post, by Lynxman
I've got this Abit VH6T that I recapped and it still doesn't work. It also had a faulty BIOS ROM so I replaced that and progarmmed it but still doesn't work. After some closer inspection I found a blown IC under the BIOS IC so I suspect that's the fault. Possibly because someone inserted a BIOS backwards at some point, blowing both the BIOS IC and this IC. It looks like part of the part number may be blown off. All I can tell is F04 which may be an SN74F04 hex inverter. Does anyone have the same motherboard available to check for me? Maybe their IC has the full part number printed.
